Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Our son pushed some buttons, and now we cannot get rid of the square in the upper right corner that says "video 2". HELP!
  • adrian32 Jul 28, 2010
    My son pushed some buttons ON the TV monitor. He did not use any remote. Now we have this black square in the upper right corner. As we do not HAVE the TV remote (we use teh direct tv one), there must be something we can do ON the monitor to get rid of this square.
    I just got a reply from the same guy
    President:
  • 1,285 Answers
Press the arrows up/down til video 1 shows (but if the tv is showing) then just press display once using the remote
here is the link to manual for future
  • http://www.docs.sony.com/release/KV34HS420rev.pdf
Posted on Jul 28, 2010
    did you read my story? what remote are we supposed to use if we don't have the remote?
  • Dvdcdlaser
    Dvdcdlaser Jul 28, 2010
    on the front panel of tv press the tv/video button continuously until box display disappear (video 1 - 5)
    by pressing menu you can also enter and change the set up of other features, by pressing menu again you will exit..hope this helps
  • 10,594 Answers
Video-2 is on-screen display. Press Display/ info button on tv remote, on-screen display will disappear.
Please note that only Sony tv remote will work to cancel on-screen display.
Thanks.
  • 2 more comments
    Hi, and thank you. We have not used out TV remote in years ( we have direct TV). I don't know where it is. Our son was able to make this appear with one of the buttons below the screen (there is a flip-down door).. Any way we can do this on the TV, without the remote? THANK YOU!
  • Shahid Electronics
    Shahid Electronics Jul 28, 2010
    With Sony tv remote, its just matter of one button push and problem will be solved. Check Sony tv remote with friends etc and press Info/ Display button on remote.
    I'm not sure how on-screen display enables with direct cable remote, press same button again on direct cable remote so it might turn Off display.
    Thanks.
    ok, no problem, it is a simple fix, one button push on Sony remote.
    We don't have the remote, and out son pushed a button ON THE TV, so there must be s button ON THE TV we can push to reverse it.
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
How do i use the square root button? I don't know how to use the gray symbols above the buttons.
Press the "2ND" key at the upper-left-hand corner of the keyboard to access the second functions. For example, to calculate the square root of 2, press 2ND [square-root] 2 ENTER.
Aug 26, 2011 | Texas Instruments TI-84 Plus Calculator
How to get rid of the "M" in the upper left hand
Try playing with the buttons on the bottom right. The M+, M-, and Mrc. You should be able to clear the "M" fairly easily.
Jun 22, 2011 | Texas Instruments TI-1795 SV Calculator
How to set up clock on kenwood kdc 138
Hello... sorry to hear you are having problems. The correct procedure is to press the "SRC" button and put the player in standby "STBY" mode. Once in standby mode, press the small button labeled menu on the bottom right corner and hold it for 2-3 seconds. "CLK" will appear. Press the small button inside of the "square" on the right side of the radio and hold it for 2-3 seconds. The clock will appear and will be flashing. Use the up and down arrows on the "square" to change the hour and the left and right on the "square" to change the minutes. After you get it set, press the menu button once more on the bottom right corner and it will take you back out of the menu. Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | Kenwood Car Audio & Video
Change language on my sony dcr-sr300
if the cam is set to a language you don't know better take note of the icons on the screen. here's how you do it:
1.press or touch home button (looks like a house icon)
2.touch settings icon (looks like a toolbox icon, its at the bottom right corner of the lcd screen)
3.go to clock/language setting page (to go there look for the up and down button on the screen, it's on the right side of the lcd. in the middle you'll see reference to the page it will show 1/2 press down to make it 2/2)
4.touch the setting that has an icon of the letter A inside a square (that's in the setting upper right portion of the screen)
5.select and touch language set (it should have the language icon, A inside a square)
6.select desired language setting
... hope you'll find this understandable and useful. thanks:)
May 28, 2010 | Sony Video Cameras
I am getting a black square in the upper left corner. How do I get rid of it?
Press CC button on the remote control until you see CC/TT OFF.
Closed Captioning or TeleText is the cause of the problem.
Dec 28, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Can't get the "Video 5" legend off the screen
check your manuel, they should be a display button to press to get rid of it, a rectangle with a + in it on the button
Oct 03, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Video Source Text remains in upper left corner of screen (video 1, video 2, etc)
If you have the original remote control, press display to get rid of it.
Hope it works.
Mar 10, 2008 | Sony KP-46WT500 46" Rear Projection...
Channel display
if you have the manua for the
universal remote that you are
using it the button that displays
current channel on the tv
or the one that say jump.
flashback or channel return
might be bottom R corner of
the remote or a small button on
either side of the zero button
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
220 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
