Question about Vacuums
I want to blow something up. How can i reverse the air flow on my vaccuum to blow insted of suck
reddevil6
  • 1673 Answers
SOURCE: Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Posted on Jan 22, 2008
Agent Don
  • 310 Answers
SOURCE: My vacuum blows air instead
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=571660
Generic problem for all Vacuums
Posted by katweaver3 on May 04, 2008
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesn’t **** stuff up anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally if your vacuum has a round belt you may have your belt on backwards, please reverse the belt and the suction will return also you may have a clog in the tube leading up to the bag or dirt cup would be anther reason for the blowing instead of suction. This is not covered under the factory warranty. Feel free to contact your local vacuum dealer for questions.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 05, 2008
  • 36 Answers
SOURCE: Hoover SteamVac Al Terrain Spin Scrub motor running in reverse
if it dosent **** up the water send it back but some hoover steamvacs blow air to dry the carpet or floor faster
Posted on Aug 01, 2009
  • 4088 Answers
SOURCE: it seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Posted on Mar 12, 2010
Testimonial: "it's fixed"
  • 354 Answers
SOURCE: I recently purchased a house
Never seen this model but it is on of two things,the hose is hooked up wrong or the motor is either switched in reverse or the motor has been reversed with wire leads
Posted on Feb 17, 2011
Dyson dc28 toubleshooting wand
Can you disconnect the hose from both ends of the unit?
I generally push a broom handle down a clogged hose, and second broom handle if needed!
You can also attach a shop vac hose to the shop vac exhaust and blow it out using the exhaust of the shop vac.
Maybe you sucked up a dryer sheet or plastic bag. Empty the unit completely and look at all the possible portals where items have to travel through.
Oct 17, 2013 | Vacuums
My Bissell proheat is not sucking. It's doing the
Hi there! You may want to have a qualified tech at one of our Authorize Service Centers inspect your machine.
Here's a quick link to locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 22, 2013 | Vacuums
Is there a switch that reverses from sucking air in to blowing air out
No there are NOT switch Normally this motor from AC, doesnot have this device for reverse. Only you can do it by open the motor and chaging the connections
Now you must shure the a) hose is clogged b) bag is clogged c) or there another thing maybe a sock. please use the common sense
However you can go to the web page from kenmore and see your instr. manual download:
http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu
Jul 27, 2012 | Kenmore 31913 Progressive Direct Drive...
My Kirby is blowing out not sucking in how do I change this?
Either there is a blower option on the vacuum cleaner that needs to be set back to where it belongs, or somebody changed the brushes on the motor and got the brush or field wire connections reversed (one or the other, but not both).
Oct 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Its a reverse vacum, not sucking up anything just blowing it everywhere. The belt is fine and the filters are clean. Please help.
Hi r_holdsworth,
You got a deal! 2in1, blows and vacuums....
Actually, when vacuums blow instead of sucking, there is a clog somewhere. Usually, it's something that has been vacuumed up.
If you can't find the clog, please reply back with your model number and I'll find an exploded view of your machine for you to look at.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 20, 2011 | Bissell Cleanview Helix Vacuum
I recently purchased a house with a Filter Queen Central cleaning system model FQ-7500. My problem is that instead of sucking air it blows the air out. How do I reverse the air flow?
Feb 17, 2011 | Filter Queen Majestic Canister Vacuum
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Aug 01, 2009 | Hoover F7431-900 SteamVac Vacuum
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesnt suck stuff up anymore.
Customer Service
Go Ahead. Use Us.
May 04, 2008 | Vacuums
Vacuums Logo
79 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
