I purchased a GoldstWG1805 6-3-08. Last night it made a popping noise and now it won't power on at all. I pushed the reset button but still no power. Once it popped it also started leaking water from the bottom. Was it a 2 or 3 yr warranty or is it fixable for a reasonable cost?
  • 3 Answers
SOURCE: Maytag Quiet Series 300
Sounds like a thermal fuse that is a less than $20 part. remove the top 6 screws in the door that hold the plastic front panel on. Behind that is a circuit board and a white flat 1" square fuse with two wires going to it. make sure power is off at breaker. Test with an meter to see if any current is going thru. If not, that is most likely your problem, and just follow the fuse replacement kit instructions carefully, including putting the new wires on the new fuse like they say. Otherwise, the original wires going to the fuse will blow it too.
Should take about 20 minutes.
Posted on Feb 12, 2008
The HVAC Guy
  • 30 Answers
SOURCE: Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Posted on Oct 30, 2008
  • 6 Answers
SOURCE: asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Posted on Dec 14, 2008
  • 659 Answers
SOURCE: Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Posted on Mar 17, 2009
Healeyman
  • 1198 Answers
SOURCE: AC Unit made pop noise when plugged in; Now will not turn on
Look in the electrical control area for a capacitor. They are round cylinders with a couple of wires going to them. A bad one will looked swollen and damaged. If it is bad, note how the wires connect and move the wires to the new one one at a time.
Posted on May 04, 2009
I changed a honeywell thermo last night. I'm
check your transformer some of them have a little reset button on the side if it arched it could of tripped it.if there is no reset make sure you have 24v coming into thermostat.
Apr 22, 2012 | Honeywell Heating & Cooling
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Hp pavilion a430 desktop. Nothing happens when I push the power button. It is dead. Is there a reset button? Had bad T-storms last night.
no there is no reset button the only thing u can do is take out the battery and unplug ur power supply ...if that dont work call hp if u under warranty they will fix it.
Sep 15, 2011 | HP Pavilion dv6000z Notebook
MY LF 60P550 won't turn on. It worked fine when i turned it off last night. Is there a reset button?
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck, Thanks
May 14, 2011 | Televison & Video
Power button won't shut off
First thing to do is unplug the reciver for 12 to 24 hours. Sounds like it needs to be reset.
Sep 18, 2006 | Denon AVR-1803 Receiver
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
