Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
I have a Roper electric over B9757XO that when you
I have a Roper electric oven model # B9757XO that when you turn it to broil, bake, or clean it works for about 30 seconds then it clicks and turns off. Any ideas?Every once in a while the "door" code comes on the display as well.
Thanks,
John
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Probably a bad oven control board. check the lock switches too while you in there messing around getting lit up lol
Posted on Jul 28, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
How do i turn on the bake option on the self cleaning oven?
to just turn on the bake option there should be a bake button to press as well as a self clean option and broil cycle.
Jun 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F3 error in roper model B9757XO
Hi. This F-3 code is representing a malfunction within the oven temperature sensor. It is open at the moment and unable to transfer data at this time.
You can test by Measuring the oven temperature sensor resistance, should be1100 ohms. If not, replace sensor.
May 16, 2009 | Ovens
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
89 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
