Question about Speed Queen AES28AWF Electric Dryer
How the belt fits around the idler pully and drive gear
  • Speed Queen Master
  • 8,220 Answers
Posted on Jul 28, 2010
Drivebelt routing diagram for a troybilt pony lawn tractor
oh oh big trouble...make sure you installed correctly re check ever thing is there a twist in the belt? not riding true on idler pully? correct belt?is belt cutting into guard housing any where? is the belt making howling noise? use veernier caliper to check dimensions of old belt to new belt.I once x out a drive belt with a generic one that did the same thing. my solution dont buy cheap chinese belts stick to OME belts as the chinese ones may not fit as intended.
Jul 09, 2014 | Troy-Bilt Pony Garden Tiller
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
How dose belly go on around idler pully
LOOK FOR TENSIONOR LOOSEN AND REPLACE BELT ALSO APPLY SOME WASHING UP LIQID TO BELT TO HELP.
Oct 18, 2009 | Estate TGDS740JQ Gas Dryer
How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Belt jumped off pullies
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
Apr 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Replace belts
It is pretty easy to change the belts. The correct size is the problem. I bought some replacements for mine and found they didn't just quite fit. I finally got them from Troy Bilt so they fit correctly. Remove the two fly nuts to the safety shield over the belts. Next remove the cotter pin that holds the idler pully to the control shaft. This will now allow you to swing the idler out of the way so the belts can be removed. A little twisting and turning and they will come out and go back in without a problem. Reconnect the idler pully and pin and make sure it is adjusted properly for operation then replace the safeth cover. Good Luck, RAC
Apr 02, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Putting a belt on a whirlpool belt
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 15, 2009 | Whirlpool LER4634PQ Electric Dryer
Surpentine belt.
depends on which v8 you have....the 4.7 the routing is as follows it goes under the waterpump pully over the alternator down and around the power steering pumpto the crank...it goes under the bottom of the crank to the idler pully.the flat side of the belt goes ver the idler then around the automatic tensioner to the ac compressor.
on the 5.2 and 5.9 it routes starting at the idler pully the flat side goes undr the idler the up to the ac compressor around the compressor and down to the power steering pump ... around power stering pump to waterpump where the flat side is against waterpump pully around water pump down and around crank up it automatic tensioner....around tensioner and up and over alternator
Nov 30, 2008 | 2000 Dodge Durango
Speed Queen AES28AWF Electric Dryer Logo
Top Speed Queen Dryers Experts
Tim Whalen
danoyachtcap
danoyachtcap
Marvin
Marvin
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
