Question about Sony Cyber-shot DSC-S750 Digital Camera
Camera turns on only for a moment
Will only turn on for a moment, just long enough for the screen to turn on and say Sony, then shuts off again
    President:
  • 1,382 Answers
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you!!
Posted on Jul 28, 2010
SOURCE:
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
When you turn it on the lens goes out and right back in and turns off
Hi Dear,
This issue is because of discharged battery. The when there is not enough power supply for the camera to support it for longer time. The reserve power supply switches on your camera for a moment resulting in roll out of the camera lens. But as the camera detects that there is not enough battery available, it agains rolls in the camera lens in and then shuts down.
Hope this is one of the reasons. Please charge the battery to the fullest and then try to use it on the camera.
If the problem persist then do write to us again. We will be glad to take your problem once again.
Have a nice day.
Nov 06, 2009 | Cameras
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Cann't shut down properly
If you are trying to shut down with the camera still connected!!??GOTO the bottom right of screen and ""safely remove hardware"" see if the system will shut down.....sometimes a hardware driver does not want to shut down so you must turn it off and plug it in again when you start windows again....
Nov 28, 2008 | Sony VAIO PCV-RX753 PC Desktop
Turning on the camera.
You can try to remove the battery to allow the circuitry to reset to factory defaults. If that do not work, I would suggest to get repair under manufacturers warranty. Most electronics devices have one year warranty.
Good Luck.
May 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W30-control buttons stuck
One button of the camera is stuck, try pressing hard all buttons various times with the camera turned off and try using it again.
Mar 05, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Digital camera
Mine is a bit different- Mine turns on to the opening "Cybershot" screen, opens and shuts about 6 times, and then says "Please shut off and then on again" or something. AAH!! Im a photographer! HELP!
Nov 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
The image turned very colorfull and grainy
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor
Aug 01, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
My camera shuts off as soon as I turn it on
Reset again. Make sure all the battery contact are clean - use a pencil eraser for the contacts in bottom of the chamber. Other than that the camera will have to be replaced- there are usually no economic repair options- though Sony may do an fair priced swapout you could at least try,.
Jun 29, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Sony Cyber-shot DSC-S750 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
