Question about Frigidaire GLTF2940ES Front Load Washer
Washer cycle was interrupted. Time and PAU is cycling on the display and washer doesn't start. Start button does not change the situation. Drum has water in it
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Unplug it and wait a minute then try again
Posted on Jul 28, 2010
I have a Frigidaire front load washer #ATF6000SF1 and need to reset the PAU and E41 error code. I cannot get the unit into diagnostic mode to accomplish this. How can I reset this code?
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
Dec 07, 2014 | Frigidaire Washing Machines
Frigidaire front loading washer will not start will not stat, I get a PAU or ERR message, tried resetting by unplugging for an hour, removed and cleaned soap dispenser, and checked door for proper closure....
Thank you for your question, Friend.
If you are still receiving an error code PAU after resetting your washer, then the door of your washer is probably not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, then your washer could possibly have a faulty door latch, door strike or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Best - Z
Aug 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Washer Model #ATF6000FS2 flashes pau
Hello Friend, this is Z. Thank you for allowing me t to assist you!
If your Frigidaire washer (ATF6000FS2) is displaying PAU, it usually means that the door is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is necessary to wait approximately ten minutes and then turn your washer on. If the issue persists, then your washer could possibly have a faulty door latch, wiring harness, or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 15, 2014 | Frigidaire Washing Machines
Cycle pauses after 1 minute
Hello Peter - Often when "PAU" displays on the screens it indicates that the door is not securely latched or the cycle has been interrupted. Try pressing "START" once to resume cycle. If it proves to be ineffective, reprogram the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the washer back on. If the issue persists, then more than likely it has a faulty door latch or a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 21, 2013 | Frigidaire GLTF2940ES Front Load Washer
My washer keeps pausing during the cycle
Hi claire64 - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and resume cycle. If fault reoccurs, then it typically means that the unit either has a faulty door latch assembly or a communication error from the control board. Since there are cost differences in parts, it is always a good idea to have a service tech properly diagnose your appliance.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
My affinity washer starts the cylce and after 2 minutes into the cycle it stops and says pau. I have tried it on several cycles and always the same thing.
The PAU is a power interruption. Look for something simple like a loose power cord or worn wall receptacle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
Need to know buttons to press to self clean.
Taken from the Use and Care guide:
To clean and freshen the washer, perform the System Clean Cycle. For best results use the System Clean Cycle once a month. To begin the cycle, press and hold the Spin Speed and Options buttons simultaneously for 10 seconds until the display changes to "CLn".
IMPORTANT
Items left in washer while performing the System Clean Cycle will cause a severe out-of-balance situation that could damage the washing machine.
REMOVE ALL ITEMS FROM WASH DRUM before filling the detergent chamber with one (1) cup of liquid chlorine bleach OR one (1) pouch of TIDE® WASHING MACHINE CLEANER. DO NOT use both. Press Start/Pause to begin.
If the System Clean Cycle is canceled or paused during the cycle, the washer will go through 2 rinse cycles to clean the drum of any residual bleach before unlocking the door.
Cheers!
Oct 29, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
