Can I change a arcoaire thermostat (mercury) with a White Rodgers Digital thermostat? The digital is very easy to install. Is is easy to dismantle the arcoaire?
    Scholar:
  • 66 Answers
If you have heat and air there needs to be 5 wires inside the thermostat, heat pump will need six. If you have heat only there will need to be three wires. If not, the new thermostat will only operate on batteries. Pay close attention to which wires go where and make them correspond on the new thermostat. Also remember mercury is a hazards waste product. Please recycle responsibly.
Posted on Jul 28, 2010
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
How can I control this thermostat manually
That thing is antique. I had same one when I bought my house in 1995. Get it replaced with a newer digital. Honywell or White Rogers. At home depot for $25.00 to $40. Get one that's for heating and cooling, but not programmable. Easy to install, smaller and doesn't even have to be level since they don't use a mercury tube inside, like the old ones. Either way, here is a link to the full owner/operator's manual for your old old thermostat. --- .https://www.manualslib.com/manual/194597/White-Rodgers-1f95-71.html#manual . copy and paste it in your address box.
Dec 11, 2017 | Heating & Cooling
The white-rodgers 1f78-144 does not work properly
Is it in the heat or cooling mode? Might try a new set of batteries.
Jan 22, 2014 | WHITE-RODGERS DIV 1f78-144 Digital...
I do not have a manual for my thermostat
You have a heat pump unit most of the time the unit will operate in normal mode heat setting on your thermostat but when the temp of house can't keep up the emergency heat will kick in. With that being said you can switch the t-stat to emergency mode and that will take the heat pump out of action and bring in the back up heat. You might have electrical heat strips or maybe a fuel such as natural gas or propane. hope that answers your question Ken
Jan 07, 2014 | WHITE-RODGERS DIV White Rodgers 1F97-1277...
I have a White Rodgers digital thermostat .I do not have the manual.I am getting a lo battery message. How do I replace the battery? Does it come off the wall or is there an easy way to open it? I dont...
The outer shell of the thermostat pushes on(clips) to mounting bracket attached to wall.
1. Remove the packing material from the thermostat. Gently
pull the cover straight off the base. Forcing or prying on
the thermostat will cause damage to the unit
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6488.pdf
This is the manual for your unit.
May 24, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
My screen went blank on my thermostat. How can I get it back on?
Normally the digital thermostat required a power source to function, please check the connect at the c- terminal if your thermostat is hardwired.
You can call this number for technical support 18002842925
Apr 25, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
