Question about Gateway Computers & Internet
Left click on touchpad randomly quit working altogether
Gateway NV52 ''left click'' button on touchpad (and double-click functionality of touchpad) is completely gone. Other than for that, the touchpad is completely normal, as is the ''right click'' button. System Restore did not work. Updating drivers from Gateway.com did not work. The button started to require me to press it really hard or repeatedly this week, and today it stopped working altogether. I purchased a USB mouse, which is inconvenient to have to use.
SOURCE: left click button below touchpad on dv8000 not working
I have the exact same problem after 1 year of use. I think this is probably a manufacturers defect from being used 'too much' i am replacing the palmrest (to get a new touchpad)
Posted on Jan 11, 2008
davepcrepair
  • 75 Answers
SOURCE: Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Posted on Mar 24, 2009
ta_mcguire
  • 125 Answers
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Posted on Jul 30, 2009
martyshaw152
  • 157 Answers
SOURCE: I've had the acer one for 2 weeks. While using it
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Posted on Aug 01, 2009
yboyandrei
  • 828 Answers
SOURCE: My touchpad will not respond when I tap it
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Posted on Aug 22, 2009
Testimonial: "Thank you so much! BINGO! I am so grateful. God bless you."
My niece clicked random buttons on my keyboard and now my left-click does not work. What can I do to fix this issue?
If all other touchpad functions work, then my guess is that the left click key is broken. The only thing that "random key pressing" might do on a laptop is to activate the touchpad disable in which case NONE of the touchpad functions would work.
Dec 31, 2014 | Toshiba Satellite L855D-S5220 Laptop
Touchpad
Have you tried both areas to double click (the middle of the touchpad and the left touchpad button)? Check your mouse properties and make sure the right click is not the one you should be hitting. Maybe the left and right got switched somehow. Go into the touchpad properties and set everything back to default.
Boot the system in Safe Mode and see if you have the same problem.
Maybe your keyboard has been hijacked so run a virus scan.
Maybe your keyboard cable is loose or the keyboard is going bad. You'll have to remove the keyboard to get to the cable.
Mar 31, 2012 | Acer Computers & Internet
Touchpad
Mar 31, 2012 | Acer Aspire 5610-4648 Notebook
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
I would like a manual so that i may use my new computer, i am on a friends computer
I'm not aware of a Gateway NV500 Series line, of Notebook PC's.
I would like you to look on the bottom of your Gateway laptop, for the exact model number.
Are you referring to the Gateway NV5207U?
It's part of the Gateway NV50 Series. (One of the one's sold at Bestbuy?)
While I wait on the exact model number, let me give you the page for the User Manual for the NV52 Series.
Never mind! 17.79MB's of anything but where the Power On button is, and what the basic parts of the laptop are!
Sheesh!
Here is the page to download the Gateway NV50 Series User Reference Guide,
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52ul.shtml
On this page scroll down to - Gateway NV50 Series Reference Guide - English, and Left-click on it.
This is a PDF file download. (The computer you are on now has Adobe Reader on it, which uses PDF files)
It takes a few seconds to see the first page. It takes an additional 24 seconds or so, to fully download the file.
I advise letting the file fully download before looking through it. Otherwise you might break the download connection.
The first page is solid Black. The second page is solid White.
Should you not be aware of how to use a PDF file, and/or, want to burn off a copy to your computer, come back, and state so.
This reference guide shows the basic views of the laptop, the various function buttons, all about the Keyboard, and other details.
On this same Gateway Support page, is the Gateway Quick Start for Windows 7. It's listed at the bottom.
The Power On button is on the Right side of the laptop.
It's in the round hinge for the LCD screen.
The symbol on it is an international one. It's a circle with a line coming part way into the top. The top middle of the circle.
This is a video on Youtube, showing a user un-boxing his Gateway NV5207u. I included it to show more of where the Power On button is, and also that there is an Enable/Disable button for the Touchpad.
Would be kind of perplexing also, if you went to use the laptop, and couldn't get the Touchpad to work.
http://www.youtube.com/watch?v=B1IB6u1iHaY&feature=related
Once I have the exact model number we can proceed forward, if the Gateway NV5207u is not the laptop in question.
Dec 27, 2009 | Computers & Internet
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Left side of touchpad not working
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Pointer/Navigator"). If there is some kind of a "Warning" icon superimposed on the "Pointer/Navigator" icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.").
Or it could be dirt or soda.
Oct 29, 2007 | Compaq Presario V4000 Notebook
Computers & Internet Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
