Question about Garmin nuvi 200W GPS Receiver
I cant change the speed on the map like how fast i go
  • 1,514 Answers
It's not possible to change the speed of the map. When you're traveling in a car if you find it's too slow you can zoom out a little by pressing the minus on the top left corner of the screen.
Posted on Jul 29, 2010
Tickover 1500 rpm when warm
idles too fast.
what engine?
what year?
on a gas engine, the idle speed is 100% controlled by PCM at all times. hot.
so its out of control that means the PCM closes the ISC valve.
and RPM will not drop. (its stuck open) or vacuum air leaks
jeeps use speed density EFI system using the MAP sensor.
this means all air leaks on jeeps , cause wild fast idle speeds.
that is all you need to know , to find problem (find leaks)
clean the ISC yet (idle speed control) valve.?
Mar 28, 2015 | Jeep Grand Cherokee Cars & Trucks
My 95 3.4 camaro ldol at 2000 rps and wont down shift what would be your guess map sensor tv cable or speed sensor ive checked pretty much every thing except Electrical how do you reset computor
None of the above.
The map sensor only measures engine vac, and the speed sensor measures how fast the wheels are turning. Neither would cause the idle speed to go up.
Chances are the idle air control valve is sticking open, the throttle plate is sticking open, or you have a vac leak somewhere allowing air to enter the intake.
Jul 19, 2013 | Cars & Trucks
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
1990 Buick Silouete loses power when accelerating, as engine warms it gets worse. Changed filter and had gas tank cleaned out recently did not solve the problem. It drives ok at normal speeds, it spudders...
You are a 1990 Oldsmobile sihouette with a 3.1 these vehicle are speed density in other word you are equipt with a MAP (manifold air pressure) when this sensor fails you loose the ability to accelerate or hesitate as you accelerate make sure the vacuum hose is connected to it and it is no leaking vacuum if the hose is okay and it is electrically connected correctly your fix is to replace the MAP sensor
Aug 05, 2011 | 1990 Oldsmobile Silhouette
Hi is there a way for us to notify someone to alter mapping that is wrong i.e. a road that you can no long go up but the sat nav trys to send you up it. and when the speed limit has been changed i.e/ from...
Yes, Garmin satnavs use Navteq maps. Go to www.Navteq.com and there's a link there called Map Reporter where they take reports of map changes. I have reported several in the past and eventually they all appeared on map updates.
Nov 02, 2010 | Garmin GPS
1998 nissan sentra lost pick up speed and is jerking
first remove your map sensor and clean it with carburetor cleaner let it soak for a few hours and then reinstall it sometimes they get dirt or carbon build up and the pcm cant tell how much fuel to send
Jan 27, 2010 | 1998 Nissan Sentra
How do I change the speed of office jet hp j3680? thanks simon
you cant change the speed of it....it prints as fast as it can all the time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | HP Office Equipment & Supplies
GPS Use
Hye! here's how you can take care of this issue: Dowload google maps from the web (for windows mobile) & install it on your diamond. In order to use GPS on this phone, your internet/gprs connection must be functional; without netwrok connectivity you cant use GPS on this device as it does not have the map interface on its chip (& cant be loaded later too). It just has a light GPS transceiver which in presence of a mapping software (such as google maps) can show your position on the globe & in some countires can also navigate you. After installing google maps, make sure your internet connectivity is on and then work with google maps 'USE GPS' & 'My location' or 'Navigate' functions ... enjoy!
Aug 25, 2008 | HTC Touch Diamond Smartphone
Garmin nuvi 200W GPS Receiver Logo
47 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
