I recently bought a new Asus M51Sr Laptop. It will shut windows down and not be able t restart it. It will not read disks in the drive at times. My mouse will quit working and I cannot get the light scribe to work. The wireless connectioanly works when it wants to and connects and disconnects all the tie.
    Novelist:
    Champion:
  • 214 Answers
This may be irrelevant, but run a full antivirus scan and a full antispyware scan. If you don't have any, you can download both of these for free from AVG (do a Google search with the string AVG Free).
A lot of people are having "similar" problems with the cause being a Trojan.
Good luck.
Posted on Apr 23, 2008
Asus laptop will not boot up after install of new hard drive
If your ASUS laptop uses a SATA hard drive -
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 27, 2013 | ASUS Computers & Internet
Hard disk cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
I CAN NOT LOG ON TO MY ASUS Eee 900HA WINDOW ,I CHANGED MY PASSWORD,AFTER SHUTTING DOWN AND RESTARTING IT REFUSES TO RECOGNISE THE OLD AND NEW PASSWORD SO I CANT LOG ON TO THE WINDOW
If you have a Windows password reset disk, you can easily reset your Windows password with it. If not, you can follow the steps to create one. You just need an available computer linked to the Internet.
Step 1: Download and install
Windows Password Breaker with the available computer.
Step 2: Run the program and burn a Windows password reset disk. It could be burned onto a CD/DVD OR USB flash drive.
Step 3: Turn to your locked computer, insert the newly created CD or USB to your drive. Reboot the Computer and reset the Windows password.
It is easy and safe to use.
Jan 31, 2011 | ASUS Eee PC 900 Notebook
I have been using HTS545032B9A300 320GB drive in my Samsung R428 laptop. One day, suddenly, its shuts down and never boots up. It never gets beyond setup. It hangs and showing "Entering into...
When start your laptop,is their any spinning sound in your hard disk(Hitachi)?
If so, try to go setup the bios ,just watch the laptop either detect or not,
If your laptop detect the hard disk ,again install to the laptop, and remove the new seagate just for recover the data through following step.
Please download hiren boot bootable ISO file ,
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Mazor problem is most of the user, burn ISO file in data mode and the result, it could not run in boot time.
Burn the iso file, under image burning option from any nero .
Boot from cd, no need to setup bios.
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORS
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Insert a pen drive
Restart your laptop and boot from cd
1.Boot from cd
2.Select mini windows
3.you can explore every drive (hitachi) and can copy paste to pen drive.
ALL IT WILL BE POSSIBLE IF YOUR HDD CAN SPIN AND AND READ .
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | Hitachi Travelstar 5K500.B...
Im having a ASUS G60 vx Laptop with the default 7200 rpm 320 mb hard disk . recently i bought a western digital 500 gb 5400 rpm hard disk and fixed it to the second slot of the laptop hoping to use the...
First Update the BIOS so that both dont conflict
And go to the BIOS configuration page and make one masrter and other new one as secondry/slave and it would work
To go to BIOS setup option keep hitting F2 or F12 or Del key while starting the system
Aug 01, 2010 | Computers & Internet
Computer shuts down, Restarts runs for a while shuts down, isn't hot. Have run reg. fix,Spy ware programs etc. Sometimes it takes 4 or 5 starts for it to stay running. Thank you for your time
Possibilities:
* overheating
* bad RAM, causing Windows to "crash"
* dying disk-drive, intermittently preventing Windows from being read from the disk-drive
* dead (seized) fan inside the computer.
So, the most-likely cure is to:
* disconnect the AC power
* remove the battery
* buy a can of compressed air
* give your computer a "blow-job", to remove all dust from inside it
Apr 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Cannot shut down
I want you to try this first reset the CMOS bat , put a new Hard disk install EXP .
good luck
Dec 19, 2009 | Acer Aspire 4930-6862 Laptop
Do I really need a floppy disk to do an upgrade bios?
Of course floppy is the easiest but if you configure a flash drive with flash drive utilities to be bootable, and the BIOS will support it you can flash from the USB flash drive.
Mar 21, 2008 | ASUS P4S800D-X Motherboard
ASUS DRW-2014l1t DVD burning problems.
Hi, try to buy optic lense cleaner of dvd.
Try also nero if also available.
Jan 19, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Illegal Operation
Hi, sounds like you might have a faulty part in the pc, ie memory or hard drive etc. if you have already installed windows from scratch on the pc and your still getting these faults i would say its the memory or hard drive is faulty..
Have a good new year
John
Dec 29, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
