Question about U-Line 75R Refrigerator
Thermostat went out what is the part # I need for replacement
    Problem Solver:
  • 4 Answers
I just replaced my thermostat on model # 75RB and it was part
# 2923-S
You can call U-Line and they will help you out and point you to a parts distributor or you can find it on the internet.
http://www.u-lineservice.com/
Posted on Aug 07, 2010
What caused replacement thermostat to fail?
The replacement thermostat could have been defective even before installation.
Mar 27, 2016 | Refrigerators
Heater is not hot
Jess:
It could be several things. Check that your coolant level in your radiator and overflow bottle are adequate. If that is okay, you need to replace the thermostat. It may be sticking causing your car to overheat and preventing the heater from working properly. If neither of these resolve your problem, then it is most like a bad heater core which is a real pain and expense to replace, and will probably require a mechanic unless your so inclined. . I'd check the coolant level and replace the thermostat before doing anything else. They're easy to do and cheap, and may correct the problem.
Apr 05, 2014 | Mazda MAZDA6 Cars & Trucks
Rvp thermostat
After you replaced the batteries, you also need to sync the remote with the receiver for it to work again. Here's the manual link: http://www.atwoodmobile.com/manuals/furnaces/MPD%2033179%20SP%201.08.pdf
Nov 02, 2013 | Atwood Excalibur 8500 IV Furnace
My 2001 VW jetta started overheating, the drivers side fan was not working. So I replaced that! Drove my car a distance and it started to overheat again, so I checked the hose going into the thermostat...
u need a thermostat or the coolant cant cool it just keeps going around and around and never has a chance to cool try to put a thermostat in and the should work
Mar 28, 2011 | Volkswagen Jetta Cars & Trucks
Help! I'm cold. Thermostat went blank. Going to
just determine what kind of system you have and make sure the new stat will work. (did u try batteries in the old stat? Is the power on to the furnace?
Sep 30, 2009 | Honeywell Programmable Thermostat Heater
2002 KIA Sedona Overheating
most likely, replace thermostat .
Apr 14, 2009 | 2002 Kia Sedona
Up in smoke
probably need a new internal thermostat, unless the coolant is leaking from somewere, you need a new thermostat. let me know if you need more info
Apr 03, 2009 | 2002 Ford Taurus
Whirlpoool dryer not heating replaced the thermostat
Dont know the model number you have, but most of your items are located in the back of the unit. You need to make sure you replaced the thermostat, and not just the thermal fuse. The thermal fuse sits on top of the element shield, the thermostat is lower, down where the wires go into the element. You may have changed the thermal fuse, but the thermostat may be out. You will need to check (with an ohm meter) all the componants to find the trouble. If that thermal cut-off has went bad again, change the thermostat with it. Be sure you have very good ventilation all the way through, bad vents will cause problems like this all the time. Let me know if you need parts info. Let me know a model number as well.
Nov 16, 2008 | Dryers
Blower not working with new thermostat
To get the fan to work, look at the heating system to see what termoinal the blue wire is connected to. It should be the "G" terminal. If so, connect the blue wire to the "G" terminal on the thermostat and then manualy switch the thermostat to "Fan On". Indicate what terminals you have on your new thermonsta ie "G" "R" "Y" "C" "W" etc... For a fan to work, typically you connect "R" to "G" on the furnace.
Nov 05, 2008 | Honeywell Programmable Thermostat Heater
U-Line 75R Refrigerator Logo
398 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Marvin
Marvin
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
