Question about Protron PLTV-32 Television
No power , lately I reaized that the TV was not responding to the remote as efficiently as it was before. Like slowly something was dying. Now I get no red power light, other devices in the same outlet work.
  • 11,361 Answers
This TV uses the AC adapter that puts out the 12vdc and the 24vdc, you may want to check that first. Notes: not all PLTV-32 use the AC adapter.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 28, 2010
I have a lg smart tv and when I switch on the sky hd box the remote work very slowly and then dies when it warms up
Check you remote battery and the connection. You may have to bend the tabs back a bit to ensure a good contact.
Not sure if you are describing the TV or the Sky HD Box remote.
Mar 16, 2015 | LG Televison & Video
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
Jul 02, 2011 | Televison & Video
Toshiba CZ36T31 will not accept remote codes for dish network
Hello!!! It has been awhile, so I do hope that you were able to get your remote working with the tv. If you have not, or are having any other troubles, here is something that will help you. Follow the link below, and you will find instructions for a power scan. the power scan scans the tv for all codes on the tv for the code that works with the remote. It sounds like a tedious process, but it is actually very quick, simple, and efficient.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
May 22, 2010 | Toshiba CZ36T31 36" TV
Tv slowly started to not respond to remote control. now it does nothing and we have to manually turn channels. i have tried every code to reprogram the universal remote, and nothing works.
I don't intend to be a smart *** but, have you changed the batteries?
The "slowly started to not respond" is a key indicator of dead batteries in a remote.
Mar 20, 2010 | Televison & Video
Unlock my remote
First of all have you checked the remote with fresh batteries in.
Check there`s no obstruction between remote and tv.
I can get the codes for a universal remote 01 or 02
try those on your sharp remote.
Another way
If you don`t have codes,I can tell you how to find the code on your remote without pressing any numbers!
Hold the code search button until the red light on the remote remains on. Then, press "TV". After this, point the
remote at your television and press the power or on/off button over and over again SLOWLY (one time every second) until
the TV turns off. DO NOT PRESS THE POWER BUTTON AFTER THE TV TURNS OFF!!! Once it does, press the "enter" button on the remote. Then, the remote should work on the TV.
Hope i`v helped!
Dec 02, 2009 | Televison & Video
Power locks die slowly
First try replace the main relay unit in drivers side door and find it on junk yard .com half price
first take out the relay on the drivers side test it
Jul 24, 2009 | 2000 Honda Accord
Remote sensor not working
either the sensor on the tv is going or the eprom chip will need to be replaced along with a crystal that is on the chip
Dec 10, 2008 | Toshiba 32AF43 32" TV
Loud popping and decrease in volume
I'm guessing power supply problems fluctuating, or main control board.
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Optek TV Remote Code
i need a control for my optek
Feb 18, 2008 | Televison & Video
Protron PLTV-32 Television Logo
51 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
