Question about Whirlpool Refrigerators
Whirlpool refrigirator, Fan runs but the compressor kicks in and right back out. Not cooling at all. Had a power outage today.
  • Whirlpool Master
  • 1,606 Answers
Replace the overload/relay which is plugged onto the side of the compressor with 2 or 3 wires going to it . This piece is easily replaceable as it just plugs onto the compressor . Be sure to have your model number with you so you get the correct replacement part . DO NOT install a hard start kit , which is junk , and a way for the parts place to make money . Always use the correct OEM replacement part designed for your refrig .
Posted on Jul 28, 2010
  • Mike Smith
    Mike Smith Jul 28, 2010
    If you had included your model number , I would have given you the correct part number .
  • 316 Answers
You've narrowed down the problem by determining that the compressor kicks in and out. Without having the proper tool to jump start the compressor, you will either have to call a local refrigerator repair service and have them test it, or purchase a compressor relay, overload, capacitor and take a chance that those got burnt out instead of the compressor.
Whirlpool WRF560SEYB Refrigerator did not turn back on after power outage, display said "cooling off"
Sounds like you had a power outage?-- did the lights go dim for a few minutes, before the power actually went out?-- Sometimes, low voltage will cause the compressor motor to over heat-- so it might have to 'cool down'-- What happened next?-- Did you try it again an hour or so later/-- Tell us more-- Mack B
Nov 03, 2013 | Whirlpool WRF560SEYB 30" french door...
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
My air is not running correct.. blowing hot air out.. what can we do to fix this problem
hi
this may be because following reasons.
1. you might have kept the temperature selection switch in heater please check it.
2.there may be leak in the AC line which might have drained the refrigirant so no cooling effect.check the line for leakage.
3.the refrigirant used may be less which doesnt give much cooling effect.
4.the cooling fan which cools the refrigirant may not working or speed is reduced which may reduces the heat transfer rate
if my answer were useful to you please vote me.
Jul 11, 2010 | 2003 Hyundai Santa Fe
Compressor not kicking in on 'cool'; or ;dry'
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
Fan running compressor not kicking on. canister feels really hot.
check that both wires to compressor are connected, trace them back to solinoid, , if the compressor isnot humming u only have 1 leg of power or it is bad
May 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The Unit does not cool. The fan, lights, etc run
check if the compressor working if it working and you get frost in your freezer back panel then your problem is in your freezer area but if your compressor not working then and the fan next to it working then the starter unit for the compressor is bad....let me know if you need more help
911service today . com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Sep 09, 2009 | Refrigerators
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Refrigerators Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
