Question about Memorex MVD2042 DVD Player
Double image of show on screen
We're watching a DVD on the progressive scan DVD player, and our TV screen is showing a split screen that has the same show playing on each side and in the middle is a yellow emblem that says PSCAN!
How can I get a "normal" screen?
With thanks,
Mark
SOURCE: memorex dvd player pscan split screen
on the back of the dvd there is a black interruptor, it should be set as PSCAN OFF. thats all folks
Posted on Jan 23, 2008
Benimur
  • 6966 Answers
SOURCE: Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 25, 2008
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Posted on Mar 18, 2009
SOURCE: can't play movie
There's a switch located on the rear of the dvd player in regard to prescan or something like that. Switch it OFF and the player should work fine.
Posted on Jun 22, 2009
SOURCE: The dvd player displays a big yellow box in the
I found the manual for this dvd player online. There is a switch on the back of the player. PSCAN is Progressive Scan. Some TV's are not compatible with this function so the switch must be turned off. This worked and I was watching a dvd last night!
Posted on Nov 04, 2009
Trying to figure out why my moves shows like this, split view on TV
turn progressive scan mode off, this tv doesn't support progressive scan, hence double image. no model no. or brand ...... please rate or comment......meder's tv service arnold ca usa
Nov 18, 2012 | Televison & Video
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Can't get pscan split screen off dvd player, DSAY
I had the same problem... there is a switch in the back that got touched
Jan 24, 2009 | Memorex MVD2022 DVD Player
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Split screen picture
Your DVD player is set to the 480p (progressive) scan mode. Place it back to the 480i (interlaced) mode and it should work normal.
May 14, 2008 | Disney D7500PDD Portable DVD Player
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Dvd player
It could be that the DVD player is set to an improper scan setting (Interlaced/Progressive)
If the TV does not do Progressive scan it can sometime sshow up as jumpy, or not show a picture at all. See if there is any mention in your manual about this setting and change it back and forth just to eliminate this as an issue.
Nov 22, 2007 | Televison & Video
Video Issue
It sounds like you have the "progressive scan" mode enabled. This changes the order that the scan lines (each horizontal line) is sent to your TV. When this setting doesn't match what your TV expects, you get this effect.
Apr 16, 2007 | GoVideo VR3840 DVD Recorder/VCR
Dvd player split screen
Could be that some combination of the progressive scan and the line input is confusing your system. Sometimes the line doubler on the TV set causes this when recieving a 480p input. If this effect doesn't reproduce on another set, then there you have it. Try turning progressive scan off, or change between the analog(yellow) video, the component(RGB), and the S video(fat one with pins). Good luck
May 20, 2006 | Samsung SV-DVD3E DVD Player/VCR
Memorex MVD2042 DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
