Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Its not making ice
I'm getting plenty of water, it cycles on and of the water pump. the compessor runs. the area where the ice is to form gets cold. but there is no ice.
  • 43,501 Answers
Check to make sure that the drain is not leaking and that you are not adding water continuously...the warm water entering will keep the ice from forming...
Also check the condenser coil or water exchange to make sure that the refrigeration is working properly...a dirty coil or not enough water through the heat exchanger will do that also...
Finally you may have a refrigerant leak and the coils are getting cool but not freezing...
heatman101
Posted on Jul 28, 2010
  • 2 more comments
  • larryscherr Jul 28, 2010
    THE WATER IS DRAINING I HAVEN"T CHECKED THE COIL YET. WHERE ICE IS SUPPOSE TO FORM IS FREEZING BUT NO ICE IS FORMING.
    HOW DO YOU MAKE SURE THE WATER DOESN'T RUN ALL THE TIME.
  • D. Floyd Kolb
    D. Floyd Kolb Jul 28, 2010
    Often times the float sticks and the water runs out the overflow....
    see if you can see the end of the pipe where the water runs to the drain and make sure that there is not water running out when the freeze cycle is going...there will be a bit of a drip.. but not a steady stream...
    The float is often on the valve where the water comes into the sump at the pump...
    heatman101
  • D. Floyd Kolb
    Come to think of it... the float usually comes apart easily and often there can be dirt stuck in it...this keeps it from shutting off....
How long after turning on the ice maker should it begin to make ice?
Ice forms rather slowly in most refrigerators, and should start producing ice in about an hour. A few things to check, first is the water turned on, I seen more than 1 valve in the water supply. If your refrigerator has a water dispenser, it should dispense water. If it does then it is probably not an isolation valve problem. If you see and hear water valve open and in some models you can reach into the ice cube forming trays and feel the water present. I have seen some that the ice forms but the motor shaft had sheared, on another the linkage had cracked and fallen off. It was making ice but could not harvest. If it is making ice and not harvesting, you generally need to replace the ice maker. You may try the model number on Searspartsdirect.com and see if they have the part that is broke.
Hope this helps and by now you have ice.
Dec 13, 2014 | Refrigerators
Lg lsc27931sb refrigerator won't cool or freez3
Sounds like the auto defrost drain in the freezer is blocked with ice and the water is draining down into the refrig box. Usual cure is to remove inside panels in the freezer to expose the cooling coils area. Then use a hairdryer to melt the ice. Plenty of rags for this. Next you must clear the ice blockage in the drain. Make a loop of #12 or #10 copper wire (bare) about 18 in long. Hold it with a pair of pliers while you heat it with the hairdryer. It will slowly melt the ice in the drain hole. Pour hot water through the drain until it come out on the drip pan below. Now you need to see why the ice forms. Just above where the drain hole is under the coils should be a calrod heater that is powered by the defrost timer to melt the ice. It sometimes gets out of position. Another possibility is the failure of the defrost timer. If you can rotate it manually see if it initiates a defrost cycle. If so and does work, check wirinf connectors at the timer. If OK replace timer.
Dec 11, 2014 | LG Refrigerators
Machine runs cold water but will not make ice, pump runs and everything else works.
Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
Oct 01, 2013 | Franklin Industries Franklin Chef FIM200...
I have a Whirlpool White Conquest Side-By-Side Refrigerator GS6SHAXLQ03, manufactured March 2003. The ice maker creates ice and fills the "holding bin" on the interior of the door. However,...
The ice will melt during the defrost cycle. Make sure your freezer is cold enough, at least -5, preferably -10. also, if your freezer is not full of food, put some milk jugs full of water in there to take up space. This will keep the temp colder when the compressor shuts off for the defrost cycle. if there is too much empty space, there is not enough mass to stabilize the temperature and keep it cold.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice cubes form a mass that do not dispense
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 11, 2009 | Kenmore Refrigerators
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Ice maker not working
I would check the ice maker assembly itself, perhaps an ice cube has not completely exited the mould,and is preventing the ive maker form cycling again
Jan 10, 2009 | Maytag 23 cu. ft. Side-by-Side...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
50 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
