Question about ValuSoft Print Workshop 2003 for PC
I bought a new Dell w/windows vista along w/ 3 programs. I successfully installed 2 but when I tried to install print workshop it acts like it's going through the process and then after a few minutes it stops. I went back to Walmart asked the sales dept. if I'm doing anything wrong. I tried another one of the same print workshop from your co. w/ no luck. What to do? Steve
  • 73 Answers
Depending of the Workshop version, perhaps the program is not "Vsta Ready". Check the minimum requirements of the program and verify if it runs with Windows Vista
Posted on Nov 02, 2008
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
How can I share my HP officejet 5610 all in one printer that is connected to my desktop that has windows XP with my windows vista laptop?
1. Unplug your USB cable from the back of the Windows XP PC and plug the USB cable directly into your Windows Vista PC.
2. The Windows Vista drivers for your printer should be automatically loaded and your printer will be installed on your Windows Vista PC. If this was successful, skip right to step 3.
If step 2 is not successful
i. Download the Windows Vista printer driver for your printer from
the manufacturers website.
1. If your printers manufacturer has not created a Vista driver
yet, retry step 2.
ii. Install the driver on your Windows Vista PC. During
installation, youll be prompted to connect the printer to your PC.
Choose the option to proceed with installation without connecting the printer.
3. After installation is complete, open the Printers icon in the Windows Vista Control Panel.
4. Right-click on your printer that was just installed and choose Properties.
5. Navigate to the Ports tab.
6. Click Add Port, then select Local Port, then click New Port.
7. For the Port Name, enter the exact network path and share name of your printer. (ex. - \\HOMEPC\Printer2) 8. Click OK and make sure that this new port is selected with a check in the checkbox.
9. Click Apply and then OK to close the printer properties.
10. You should now be able to print from your Windows Vista PC to a shared printer located on your Windows XP PC.
Jun 17, 2010 | HP Officejet 5610 All-In-One InkJet...
How can i turn on the print spooler on my dell 922?
Please follow this steps
1. Disconnect the USB cable from the computer.
2. You need to stop the printer spooler service as follows:
a. Click Start.
b. Type ‘cmd’ in the Start Search box. -Search results should appear-
d. Right‐click on ‘cmd’ in the search results, and then select Run as Administrator.-The command window will appear- (black window)
e. Type ‘net stop spooler’ into the command window and press <ENTER>.-The Print Spooler service should now be stopped-
Next, delete the printer drivers from the system as follows:
---Warning--- These steps will remove drivers for ALL printers installed on the system.
1) Click Start.
2) In the Start Search box, type ‘C:\Windows\System32\Spool\Drivers\w32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
---NOTE--- There may be some files that will not delete because they are being used by Windows.
Click on the Ignore button to bypass deleting these files.
With the drivers uninstalled we now remove the Dell printer software.
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
You need to delete the Dell printer from the printers list.
1) Click Start
2) In the search bar type “Printers” and press <Enter>
3) Select any and all Dell printers and press <Delete>
Now delete any OLD drivers from the Server Properties Window.
1) Click Start
2) Type Printers into the search bar and press <Enter>
3) Press <ALT> to bring up the file menu.
4) Select Run As Administrator then Server Properties.
5) if the UAC window appears just click Continue.
6) Click on the Drivers tab.
7) Select any Dell printer drivers listed.
8) Click Remove, and then select Remove Driver and Driver Package.
9) Select Yes to confirm removal of the driver.
10) The system will now scan to see if it can remove the driver.
11) Once it has finished scanning click on Delete.
-Repeat the last 11 steps for each Dell printer driver that is installed.
At this point, you should be able to install the latest printer software for Vista from http://support.dell.com and be able to print successfully.
-NOTE- It’s been reported that some driver installations in Vista can take up to 10 minutes. Be patient and please wait for the driver to fully installed.
Hope this steps will resolve the problem
Sep 21, 2009 | Dell 922 All-In-One InkJet Printer
I have a relatively new Toshiba which has windows vista. I've installed Print workshop 2008 and everytime I try to add a new sheet to create a book for a scrap book I receive An unhandled exception has...
Hate to say it, because I use Vista myself, but it seems that the program "Print Worshop 2008" not really that compatible with Vista...even though they claim that it will work fine. Just another compatibility bug within the two programs. Try first updating your system with all patches, and service packs, or download 2009 version of Print Workshop. I would also try contacting Valusoft.(Valusoft.com). Ask them to send you the newest version (they should send it to you for free if you bought the older version and it is not working)
Aug 13, 2009 | ValuSoft Print Workshop 2003 for PC
Dell 946 will not print after one print
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
3) Click Programs.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Dec 19, 2008 | Dell Photo 964 All-In-One InkJet Printer
Is lexmark 8300 printer conpatible with window vista?
Ok here we go
unplug your printer (from usb)
1.) Click start / right click my computer choose properties
2.) choose device manager
3.) right click on anything on the tree view and choose scan for hardware changes
5. put in your printer driver an begin the instilliation process
6.) when it ask to connect your printer connect it and ensure it is on
7.) it should detectyour printer automatically
8.) if it fails to do this, leave the program running and repeat steps 1 to 3 it will find your printer and install it..
9.) if that still fails click start / control panel / classic view and then choose Problems and reports..
A MISSING DRIVER problem should show up there. select it and choose solve problem via the internet..
Jan 11, 2008 | Microsoft Windows Vista Ultimate Edition
DELL A940-Good connection-no printing
1) Click Start.
1) Click Start.
3) Click Programs.
Nov 29, 2007 | Dell A940 All-In-One InkJet Printer
Ulead dvd workshop 2
You can install and run a Ulead software for Windows XP on Windows Vista by running
the Program Compatibility Wizard. We do not guarantee full stability for Windows Vista though.
To run Program Compatibility Wizard:
1. Open the "Program Compatibility Wizard" by
clicking the [Start] button, clicking [Control Panel], clicking [Programs],
and then clicking "Use an older program with this version of Windows".
2. Click [Next] when the "Program Compatibility Wizard" dialog box comes up.
3. Select "I want to use the program in the CD-ROM drive" and click [Next].
If the installer is not detected from the CD-ROM drive, please manually browse for the installer executable.
4. Under "Select a compatibility mode for the program" step, please click on "Microsoft Windows XP (SP2)" and click [Next].
5. For the display settings, please click on "Disable Visual Themes" and "Disable desktop composition" then click [Next].
6. Click on "Run this program as an administrator" and click [Next].
7. Click [Next] to start testing the compatibility settings.
This will launch the installer so if you have your firewall enabled, it will prompt for a permission request.
Please grant permission for the setup to continue. 8. The setup will now run.
You can allow it to finish or switch back to the "Program Compatibility Wizard" dialog box.
9. It will ask you if the program ran correctly. Click "Yes..." if no other pop-ups appear.
* Try another compatibility setting if it reports a problem with the display. For the display settings,
enable the option "Disable display scaling on high DPI settings" as well.
10. For this next step click "Yes" to send the info to Microsoft and finish the process.
* Now that you have the software installed, you will also have to run the "Program Compatibility Wizard"
for the application to run correctly. Use the same procedure except for step [3],
select "I want to choose from a list of programs". Follow the same procedure for the other steps until you finish the setup.
Nov 16, 2007 | Ulead DVD Workshop 2 for PC
Dell A920 with Windows Vista
Believe it or not... the driver is buried on the Dell site for Vista 64-bit. I search and searched ... and there it was.
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R153048&formatcnt=1&libid=0&fileid=203948
In any case, I downloaded it, installed it, and it works fine. All the buttons (scan/copy) on the top work as well as printing. Now if I could just get my old XP machines to print to it on the network. But.. I think that is another thread.
Oct 27, 2007 | Dell A920 InkJet Printer
ValuSoft Print Workshop 2003 for PC Logo
88 people viewed this question
Top ValuSoft Computers & Internet Experts
Mike
Edwin
Martin Murray
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
