Question about Toro Lawn Mower With Toro Power Tools
NEEDED: Toro LX500 Riding Mower Drive Belt diagram/instructions
I have a TORO LX500 Riding Mower. I am needing a diagram and/or instructions on replacing a DRIVE BELT. Model No. 13AP60RP744
  • rpms Jun 28, 2013
    I found teh manual for the LX460 but it's the same macnhine: seehttp://www.scribd.com/doc/31404351/TORO-...
5 Suggested Answers
  • 744 Answers
SOURCE: toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Posted on Mar 19, 2009
SOURCE: Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
harlan301
  • 205 Answers
SOURCE: I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Posted on Oct 13, 2009
goldenglove1
  • 144 Answers
SOURCE: i have a toro lx500
Check the belt on top of the mower deck. Make sure the belt didn't slip off or break.
Posted on Aug 04, 2010
What type of oil do I use in my Toro LX500?
In the northern US, I would use a 5W - 30 year round, or 30 in the summertime. Do not use "non-detergent".
In the southern US, I would use a 10W - 30 or 30 in the summertime. No non-detergent.
Nov 06, 2015 | Toro Garden
How do I replace a drive belt on a toro ride on mower model CV18S
+check with dealer, the service manager may help cheers.
Jan 12, 2015 | Toro Garden
I have a toro lx500 riding mower. the blades won't engage.
Aug 04, 2010 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,390 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
