Question about Refrigerators
I have a maytag side by side with water/icemaker. model msd2456dew. it has frozen up in the freezer, under the white interior paneling. we think this is what is causing the cool air to not filter into the fridge portion. we have removed the interior panel several times in the last couple months and allowed it to complete defrost. we have removed chunks of ice from the interior behind the panel. it works for a while. we then start noticing after a few months that the fridge isn't staying cool again. i have not changed the water filter as of yet. i also noticed a slow leak this time when we completely removed the ice maker. have noticed water building up in the ice tray near the back of the ice maker (i think due to slow leak). do we need to add new freon to the fridge? any suggestions for us? Appreciate your assistance!!
  • Refrigerators Master
  • 1,606 Answers
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Posted on Jul 28, 2010
  • 316 Answers
Sounds like you are not defrosting, could be the defrost heater element, termination limit control, or the defrost control, could also be a bad fan motor, some other blockage of air in the system.
The leak could be due to the ice melting when the refrigerator isnt cooling properly, could also be a crack in the ice maker or an ice maker solenoid failing to close properly.
If you needed freon you wouldnt have ice building
I shut the water off to my house when I'm out of town. Now my icemaker doesnt get water. The line is not frozen.Did I ruin the water valve. mod # msd2456dew
take the cover off of your icemaker and use a 12 ga wire about 4" inches long with the ends stripped an inch. use the wire as a jumper and stick one end in the hole labled N and the other end in the hole labled M for 5 sec and remove. turn your icemaker off when you turn off your water
Mar 26, 2011 | Maytag Refrigerators
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
Maytag bottom mount freezer (top) icemaker not working
check to make sure that your fill tube is not blocked with frozen water.
if there is no restriction then you have a faulty ice maker.
Apr 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Maytag Icemaker freezing up
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
 You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
Aug 31, 2009 | Maytag Freezers
Water coming out of the freezer compartment into main unit
I believe the drain is blocked behind the panel wall inside freezer. You will need to unplug the refrigerator and remove panel and inspect drain at bottom of evaporator. There is a tray with a drain hole on the low end. Also check around area that water enter from back of refrigerator to ice maker. Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not filling with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 01, 2009 | Maytag MZD2669KE Side by Side Refrigerator
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
587 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
