I try to open Oracle self study cd through netg but i got a blank screen.
I have case cs with fault 91
Error Codes and Descriptions - Oracle Documentation
docs.oracle.com/cd/A97688_16/.../errorcod.htm
Oracle CorporationEach error entry contains a description of the error, the probable cause, and the .... Incases where one writes new mapping it is possible to get this exception.
Jul 28, 2015 | Cars & Trucks
Only blank pages printed out of Oracle
does the machine print ok with word, web papge pdf, etc if so its the oracle issue, or just the oracle file try other files?
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2014 | Konica Minolta Office Equipment & Supplies
Yellow light on front and back panel with no display on monitor
Have you connected to the ALOM to see what is going on during boot? The yellow light is just an indication of a problem, but will not give the much information by itself. This ALOM will provide info before the monitor is initialized. Docs about the ALOM are here: http://docs.oracle.com/cd/E19088-01/v240.srvr/819-4208-10/alom.html
and here:
http://docs.oracle.com/cd/E19102-01/n440.srvr/819-2445-11/intro.html#70482
You will need to connect to the serial port (RJ-45 connector using an crossover cable to the ALOM) from a laptop/PC/terminal and use some type of terminal software to connect over the Serial port of the laptop/system to the ALOM serial port. You may need to try different rates, but settings should be defaulted at 9600 Baud, 8bits, no parity, 1 stop bit.
More info here: http://docs.oracle.com/cd/E19102-01/n440.srvr/819-2445-11/configure.html#17306
A successful connection over this will show readable text a few seconds/minutes after powering up the system.
Sep 06, 2013 | Sun Fire V240 Server
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services but i dino abythin further.
Follow these steps:
  1. Open the Windows Services utility: From the Start menu, select All Programs, then Administrative Tools, and then Services.
  2. If any of the following Oracle services exist and have the status Started, then select each of the services, and click Stop:
    • OracleXE
    • OracleXETNSListener
    • OracleJobSchedulerXE
    • OracleXEClrAgent
    • OracleMTSRecoveryService
  3. Exit Services.
See also the Microsoft online help for more information on stopping services.
7.2.2 Step 2: Remove the Oracle Database XE Registry Editor Settings Follow these steps:
  1. Log on to Windows with Windows administrative privileges.
  2. Ensure that you followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop the Oracle Database XE services.
  3. Start the Registry Editor at a command prompt:
    SYSTEM_DRIVE:\> regedit
  4. Go to HKEY_CLASSES_ROOT.
  5. Delete the following keys:
    • NEED TO CONFIRM THE XE-SPECIFIC ONES.
  6. Go to HKEY_CURRENT_USER\Software.
  7. Under Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs, delete the Oracle Database 10g Express Edition key.
  8. Go to HKEY_LOCAL_MACHINE\SOFTWARE and search for the ORACLE group key.
  9. Expand the ORACLE group key and then delete the KEY_XE and OracleMTSRecoveryService keys.
  10. Go to HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI.
  11. Expand the ODBCINST.INI key and remove the Oracle in XE key.
  12. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services.
  13. Delete the following keys:
    • OracleServiceXE
    • OracleXEClrAgent
  14. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application.
  15. Delete the Oracle.xe key.
  16. Exit the Registry Editor.
  17. Restart your computer.
7.2.3 Step 3: Update the System Variable Path Follow these steps:
  1. Open System from the Control Panel.
  2. In the System Properties dialog box, click the Advanced tab, then click the Environment Variables button.
  3. Select the system variable Path and edit the Path variable to remove the Oracle Database XE entry. For example:
    C:\oraclexe\app\oracle\product\10.2.0\server\bin;
  4. Save your changes and then exit the Control Panel.
7.2.4 Step 4: Remove Oracle Database XE from the Start Menu and Desktop Follow these steps:
  1. Select Start, then All Programs, and then Oracle Database 10g Express Edtion.
  2. Right-click Oracle Database 10g Express Edtion and from the menu, select Delete.
  3. On the desktop, right-click the Get Started with Oracle Database 10g Express Edition icon and from the menu, select Cut.
7.2.5 Step 5: Remove the Oracle Database XE Directories Follow these steps:
  1. Ensure that you have followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop all Oracle Database XE services.
  2. From the Windows Explorer, navigate to the directory where you installed Oracle Database XE, for example, c:\oraclexe.
  3. Right-click the Oracle Database XE installation directory and from the menu, select Delete.
7.2.6 Step 6: Install and Run the Windows Installer CleanUp Utility Run the Windows Installer CleanUp utility to remove the Windows Installation configuration information for the Oracle Database XE installation. You can download it from Microsoft at:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
he deinstallation completes, click Finish.
Sep 14, 2010 | Oracle Database 10g
What is the difference between oracle developer and standard edition. Can any one help me in giving the reference URL.
Here's a great reference URL:
http://download.oracle.com/docs/cd/B19306_01/license.102/b14199/editions.htm
Best regards!
Nov 17, 2009 | Oracle Database 10g
Unistalling Oracle
You will need to re install it and then uninstall it for cleaning it completely, but it will still shows information in registry as long as registry does not deletes it after few months.
You can also manually delete it from your program file folders.
Sep 11, 2009 | Oracle Database 10g
Uninstalling oracle 10g from vista
To uninstall oracle from your PC,
first you should run the oracle setup from the installation disk.
The installation setup will automatically detect the oracle products installed in your PC.
After checking the list of installed products, mark the programs you want to uninstall & then click on uninstall.
Apr 11, 2009 | Oracle Database 10g
Fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Aug 13, 2008 | Xerox Office Equipment & Supplies
Installation problem of oracle in vista
If you uninstall the programs or Windows components you should have a backup for them before uninstalling.
If you have a registered vista cd you can uninstall all system and install again using backup copies for security.
Cause some vista in new computer don't need cd backup they have that installed.Just click backup oracle 9i and try.
Jun 11, 2008 | Computers & Internet
Computers & Internet Logo
155 people viewed this question
Alun Cox
David Payne
David Payne
