Question about Siemens Gigaset 2415 Cordless Phone
Hola mi nombre es Jaime y me gustaria que me ayuden a actibar mi telefono inalambrico. siemens modelo 2415 me pide el numero de pin y el numero de key y no los tengo se me estrabio el manual de operacion quisiera aver si me pudieran ayudar a activarlo grasias ... mi correo electronico es .... djborismx@gmail.com lo compre ace como sinco a&os mas o menos grasias por sus atenciones
3 Suggested Answers
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
cindy4195
SOURCE: como puedo volver a registrar
primero tienes que presionar la tecla de registro/localizacion que se encuentra en la base por aproximadamente 3 segundos como minimo, luego la sueltas y le das en menu OK, luego configuracion OK, auriculas OK, Reg, auricular OK, y ahi te pide el PIN, son 0000 (cuatro ceros) OK, y eso es todo, tarda un minito o menos en registrarse, si tienes mas de un telefono, con cada uno de ellos tienes que hacer el mismo procedimiento y eso es todo, espero aun te sirva :)
Posted on Jul 30, 2012
Westinghouse tv codigos
Hola Disculpe es que necesito saber el c?digo de mi televisi?n westinghouse tv y la serie de mitele es 6616122805042 modelo LD-2240 mellamo Pedro gracias
Jan 03, 2014 | Televison & Video
MI TELEFONO REQUIERE ALGO QUE DICE EN LA PANTALLA "NIP" QUE HAGO ??
Hola, creo que a lo que se refiere NIP es Numero de Identificacion Personal, es mas conocido por su abreviatura en Ingles PIN, puede ser el PIN del telefono o del SIM card (llamado comunmente CHIP), si es el PIN del SIM card usualmente el operador pone cuatro ceros, si es el del telefono habria que buscar en el manual del mismo cual es de fabrica (default).
Mar 02, 2011 | Computers & Internet
Como programo mi dvd panasonic con el control de dish???
Hola! mi nombre es Kimberly Escobar representante con DISH Network servicio al cliente, Entiendo que necesita ayuda programmando su control remoto a su DVD, seria mi placer proveerle las intrucciones e informacion que le pueden ser utiles para que usted pueda programar el control. Para que el control puede funcionar con su DVD existen ciertos codigos que se pueden integrar al control para que pueda funcionar el DVD. El procedimiento es el proximo: en la parte de arriba del control va a oprimir el boton transparente que diga AUX hasta que los demas botones se prendan en rojo, luego deja de oprimir el boton e ingresa el numero 1 seguido por un codigo para el Panasonic DVD por ejemplo 1639. (639 es el codigo) pero siempre van un numero 1 al principio. luego oprime el signo de numero (#) el boton AUX deve iluminarse 3 veces. Despues de eso puede tratar de usar el control con su DVD. Desafortunadamente no le podemos asugurar que funcione pero si gusta tambien nos pueden llamar directamente para obtener ayuda y mas codigos para el DVD. Gracias espero eto sea de ayuda para usted.
Dec 27, 2010 | DISH Network IR Remote Control
Como programo la caja del dish
Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
Aug 04, 2010 | DISH Network IR Remote Control
01 nissan sentra- check engine light on found codes-p0171 system to lean bank 1 p0172 system rich bank 1 exhaust smells like raw fuel vehicle does stall sometimes only at idle at stop lights
hola mi nombre es victor y tengo un nissan sentra y stoy tratando de pasarle emicion pero cuando voy para motor beiculos el carro ensendio un chec engine y me *** los codigos p0134 p0325 p0171 si tiene alguna idea que puede ser mi numero de telefono es 2039790930 y mi correo es victorleiva79@yahoo.com
May 15, 2010 | 2001 Nissan Sentra
Identificador de llamadas
Yo no conozco ese producto, pero te puedo ayudar si me identificas el manufacturero (fabricante) y el detalle del modelo. Es posible que ese manufacturero tenga instrucciones en espa?ol. Si no, puedo hacer la traducci?n al ingl?s. Estoy en Puerto Rico y soy bilingue,
Mar 26, 2017 | ATS 4121CCL Twin Cordless Phone
Telefono inalambrico kx-tg3031s
you may coldsolder the flash ic and cpu
May 28, 2008 | Panasonic KX-TG3031S Cordless Phone
Siemens Gigaset 2415 Cordless Phone Logo
130 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
