Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Envision LCD EN-7100e Monitor "Input not supported
I had this monitor hooked to a different computer and it worked fine. I have another computer with a CRT monitor and replaced it with this Envision LCD monitor and I get a message "input not supported". What does this mean????
  • lyzyrd Jan 05, 2009
    My sister just gave us this Envision monitor and once I plugged it in, it started to say "Input not supported," even though, aside from the message scrolling across the screen, it seemed to be working just fine. I don't know how to readjust any resolution settings or anything like that so I don't know how to go about trying to fix this based on the suggestions posted by other people. Please help!!
  • 180 Answers
Either your display card is not supporting the LCD resolution.
Posted on Apr 24, 2008
The problem was the resolution setup on the old crt monitor was not compatible with the new lcd monitor. I changed the resolution to one suggested/recommended by envision and the problem was solved.
How can I increase brightness?
Download and read the manual
Jul 18, 2014 | Envision EN-7100e 17" Flat Panel LCD...
Input not supported
The repair shop set the PC video resolution to higher resolution to use with their monitor and did not put it back to the same resolution for your monitor which cannot handle the higher resolution. You need to lower the PC video resolution to the native reslution of your monitor which is 1280 x 1024 @60 Hz.
Jul 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Color calibration Envision 17" monitor
Return to dealer for service, This is a common problem of a bad backlight on LCD Monitors. If it is on the top comming down it is the top lamp,from bottom up is the bottom lamp. Hope this helps you .
Dec 17, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision 17inch lcd Monitor problem
This problem is a failing of the backlight circuits. the lamp is either failing or the power circuit is failing, causing the lamp to dim down it power output. Return to dealer for service. Hope this helps you.
Envision LCD
That mean your logic board of the LCD need repaired or replaced.
Apr 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
831 people viewed this question
Top Envision Computers & Internet Experts
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
