I have this digital sling psychrometer when I turn it onIget a read out that reads E-5 what does this mean and how would i get a instruction book?
  • nicehitsam Jul 28, 2010
    thanks as always you do a great job
  • 662 Answers
Which model is it ?????
Posted on Jul 28, 2010
  • 1 more comment
    model THWD-!
    model THWD-1
  • Luke Bradford
    Luke Bradford Jul 28, 2010
    ok, this was made by amprobe and has been replaced, due to being obsolete. I do not have current details on this model, but if you head over to www.amprobe.com. you will find a support link, click that boxm and it will give you the option of "contact support", where for no charge, an amprobe rep will email yoiu back with a response within 48 hours. This is one of those companies that has great customer service support, where they will help and support their customers.
    This would be your best bet, than being misled to all sorts of possibilities.
How To Read A Book In An Effective Manner?
This question might seem to be a simple question for some people. However, only a few know that you want to read a book completely. It means that you want to understand the contents entirely. To get the right answer to your question how to read a book.
The best thing you can do is to visit the website: http://howtoreadabookwell.com/education/how-to-read-a-book-well/
This website will rightly meet your requirement and right from fundamental reading techniques, you will learn speed reading techniques as well if you already have some experience in reading books. Thanks to the website for offering such a service to motivate reading among masses.
May 25, 2018 | Book Computers & Internet
Tip
Accurate Charging Methods of Central Air Conditioners
The charging (of an air conditioning system) alone can have a substantial impact on system operation costs. A few percentage points of over-or undercharge can raise electricity consumption significantly and shorten the life of the compressor." <span style="font-weight: bold;">You must invest in the proper tools, training and methodology to accurately charge an Air Conditioning system so that it works at maximum efficiency. Using the Thermocharge method to charge your air conditioning systems to the exact charge needed will save hundreds to thousands of dollars in electricity and maintenance costs over the years! </span><br /> Thermocharging method<span style="font-weight: bold;"> </span> <p style="font-weight: bold;">Skilled technicians will <b>"Thermocharge"</b> your air conditioning system with an exact refrigerant charge. This procedure produces an exact charge . . .not approximate, but exact. The Thermocharge method requires special equipment and training to use. Your installer uses the following instruments:<br /> <p style="font-weight: bold;"><br /> <ul> <li>1. An electronic thermometer</li> <li>2. Sling psychrometer or electronic humidity measuring device</li> <li>3. Refrigerant pressure gauges</li> <li>4. Accucharge slide rule calculator</li></ul> <p style="font-weight: bold;"> Here the tech is using the sling psychrometer to obtain the indoor humidity and indoor air temperature. He will double-check his figures with the electronic thermometer laying on the table. He will also verify the readings with an electronic psychrometer. <br /> <p style="font-weight: bold;"> After recording the indoor humidity and temperature the tech will go to the outside condensing unit to take additional readings. These are the following: <br /> <br /> <ul> <li>1. Outdoor temperature</li> <li>2. Indoor humidity</li> <li>3. Temperature difference, between air entering the evaporator coil, and the air leaving the evaporator coil</li> <li>4. Suction line temperature</li> <li>5. Suction line pressure</li> <li>6. Liquid line pressure (smaller copper line)</li></ul> <p style="font-weight: bold;">Enter this information into his special slide rule calculator to determine the exact amount of refrigerant to put into your air conditioner. <br /> <p style="font-weight: bold;">Let it run for about ten minutes to verify his figures. If there are any discrepancies, start the procedure all over again from the beginning. <br /> <p style="font-weight: bold;"> This Thermocharging method of charging an air conditioning system takes time and patience, but it guarantees that theair conditioning system will operate at peak efficiency all season long. <br /> How does accurate refrigerant charging help? <span style="font-weight: bold;"> </span> <ul> <li><b>Improved comfort</b> - A improperly charged air conditioner will not dehumidify properly.<br /><br /></li> <li><b>Lower maintenance costs </b> - A poorly charged system will not properly cool or lubricate the compressor . . .significantly shortening its life.<br /><br /></li> <li><b>Better cooling and efficiency</b> - Improper charging means that the air conditioner will not provide enough cooling on hot days, causing the system to run longer.<br /><br /> </li> <li><b>Improved efficiency and lower electric bills</b> - Poor heat transfer from improper charging results in increased power consumption. A 15% undercharge or overcharge can result in a 25% decrease in efficiency. This means that the homeowner's electric bill will be 25% higher than necessary. As the charge drops farther, efficiency decreases faster to 50% or more.<br /><br /></li> <li><b>Increased reliability</b> - A poorly charged system will not properly cool or lubricate the compressor . . . significantly shortening its life. Even if you have extended warranty by a heating company, you will either be greatly inconvenienced or even end up paying for the repair if the company stalls and you end up paying another company for the work . . .a $300-$700 repair that will void the warranty. </li></ul>
on Jun 05, 2011 | Heating & Cooling
Why did it stop condensing water?
The condenser can only remove humidity if there is still humidity in the air. What's your Relative Humidity? A manual sling psychrometer is cheap enough to check it.
Jun 14, 2015 | Maytag M7DH45B2A Dehumidifier
The security light on the oil gauge of my 2011 miata keeps flashing even when motor is turned off
You better check the oil and read the instruction book, they gotta tell you what that means.
Feb 18, 2015 | 2011 Mazda MX-5 Miata
What is an ecm code?
My guess is you are hearing rumors.
and now want to know what
a check engine light means, (means get it serviced)
the book on the car covers all this is you like to read.
the book is a FSM, factory service manual or SM.
i close match is at Mitchells' DIY dot com, google it.
all mech, use it. so not have to memorize , 1million DTC errors.
it the CEL lamp means get car serviced, or learn to scan it and read the book. each error is covered in the book, if you can read.
Jun 12, 2014 | Isuzu Rodeo Cars & Trucks
Is there a way to test indoor air quality in my home ?
Yes. There are few many indoor air quality testing & building performance firms that do air quality testing. Some specialize just in this discipline.But keep in mind that even the best HVAC system needs fresh air from outside. Also i've heard a thing called a sling psychrometer. it measures moisture content in the air. you want 50% humidity. all HVAC companies have them.
Dec 23, 2013 | Building Health Check Llc Indoor Air...
How do i mark the books to show that they have been read
Unfortunatelly Kindle does not have this feature. But the books you read get pushed down the list.
Or you can delete the book by using these steps:
1. Select a book and click the left arrow on the 5-way button that brings up a delete button the screen.
2. Press the center button and you delete the book.
Another option is to move the book to a collection this is like to archive the books you already read.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 09, 2011 | Amazon Kindle Wireless Reading Device
When I drag files to my Book is says file could not be moved because Book cannot be modified. What does that mean?
if its set as a read only file you cannot change it in any way just right click on the file goto properties and uncheck the box that says read only.
Jan 30, 2011 | Western Digital My Book Essential Edition...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
