Question about Husqvarna 22HP VTwin Hydrostatic 42" Cut Riding Mower
The engine will run if I hook up jumper cables to
I have a Husquvarana 22Hp 'v twin riding mower with a 42" deck.
The engine will run if I hook up jumper cables to my truck and jump start it, but as soon as I disconnect the jumpers it will stall out. The main 20 amp fuse is ok and the battery has 10 volts in it. Can you tell me what the problem is?
    Brigadier General:
  • 3,911 Answers
The on board electric system is not working, you lose your spark when you remove the jumper cables, this tells you the mower is not making its own electricity. So either the alternator or its regulator, or both have gone south.
With the engine running, you should have just above 12 volts at the battery.
So find a manual, locate the alternator/generator, and be looking in that area for a broken connection, blown fuse, or bad component.
Posted on Jul 30, 2010
Testimonial: "Thanks! "
Ow do I tighten the belt on the mowing platform
Most JD mower decks use a spring loaded tensioner on their belts. Make sure that the belt is threadded thru the pulleys the right way and you may find that considerable effort is required to set the tensioner in position. Be very careful to ensure that if the grip slips the spring flies away from you. I use the hook on a cargo strap to pull mine into position. Normally there is a similar tensioner on the drive belt for the wheels. This is more challenging to get to.
Sep 28, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
I have a Z4235 22hp Kawasaki with a 42 inch deck. The mower does not evenly. What can I do?
make sure you dont have a bent blade.if not check the mandrel housing and level the deck
Aug 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a Poulan 733-864 14.5 Briggs motor. I cannot get it to start. Battery tested fine but there isn't enough oomph to turn the motor. The starter has a rusty nut and post where the cable attaches. ...
i would start my car/vehicle and hook up a pair of jumper cables and jump the mower, more then likely the battery is out, Wal-mart sells them for around $30. Remember to hook the cables to the mower fist, making sure you will be able to sit on the seat without causing the cables to short out, then hook them to the vehicle, depending how far gone the battery is you may or may not need to start the vehicle. Good Luck Tim
Nov 07, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Hello - I have craftsman 42 inch deck mower with a kohlar engine that does not start. Battery appears fine, when I turn it - it clicks with the head lights turning on. Ang ideas on how to get it started?...
With the key in the run position, using a jumper cable, jump from the positive post on battery to terminal on starter motor. If it runs you have a solenoid or ignition switch problem. (assuming all electrical connections are clean). If it doesn't crank the battery is the culprit.
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will...
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
Oct 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 22HP VTwin Hydrostatic 42" Cut Riding Mower Logo
220 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
