Question about HP Office Equipment & Supplies
2 problems printer cuts off lAST 2 LINES OF EDITORIAL and I have no directions to scan
    Problem Solver:
  • 10 Answers
Go to control panel, click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Posted on Oct 02, 2010
Last newsweek oboma editorial
The same as the previous weeks.
Jul 13, 2014 | Computers & Internet
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
OfficeJet Pro 7590 cuts off last line
Check the format of paper.If it "letter"may have this problem.Change to "A4" and try again.
Oct 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Last line or two of print gets cut off
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Jul 29, 2009 | HP Photosmart C7250 All-In-One Thermal...
Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Jun 08, 2009 | Epson TM-U220 Matrix Printer
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
My C6180 All in One constantly chops off the last line on a page
the problem no on your printer, that is your computer problem, when you click print on your computer you have set up size or direction, try it ,
Dec 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Scanner problems
You may have a printer driver error.
Remove the USB cable from the PC.
Uninstall the printer from Add/Remove Programs from control panel.
Get your printer driver with the CD that came with it and install the printer again. Or download latest printer driver from canon - type "canon mp510 driver" into google.
Install new driver.
If its still not working, it may just be a connection problem between your computer and the scanner - check the USB cable is ok.
If its not that (more than likely not) then the workaround is to go into MPNavigator on your PC (start programs, printers, Canon MP510, Canon Utlilities, MP Navigator 3.0 (or whatever version ures is ))
then you need to set a short cut to that... it allows you to scan directly from that program.
Hope it works
Jul 17, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Bottom of page is cut off sometimes printing from vista computer
I had same problem with Vista machine and hp c309 printer cutting off 1/2 of last line. Tried all other listed fixes and none of them worked. Eventually I found a fix that worked for me though.
1. Go to the control panel and select the printer
2. Right click and select Properties
3. Go to the Ports tab
4. Uncheck 'Bidirectional Support'
5. Click apply.
Hope this helps! It worked for me.
Jul 08, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
