Question about Arris DSR922
Skew not holding
The skew doesn't hold from channel to channel or satellite to satellite. It won't even hold the skew on G1 to get updates. Every time we want to watch something, I have to go in and reset the skew.
This all started Saturday with we turned the unit on to find it blank. There was nothing there and I had to unplug, then reprogram the whole thing from scratch.
  • 78 Answers
One way is to go out to the dish and physically turn the feed assembly 90 degrees one way or the other. you could be having a problem with the polarotor motor. they are inexpensive now(less than 20 dollars) and really easy to replace. it is the little box on the feed, has three wires coded white, black (or blue) and red.
Posted on May 03, 2008
Km c253.. all colors skewed
Black image unit is the reference for registration might have a bad unit.
Jun 12, 2014 | Konica Minolta Office Equipment & Supplies
Can not locate satellite continues to search
There are few possible reasons.
Antenna can't "see" satellite.
Wrong data programmed.
Wrong skew angle.
Damaged RF board.
If you make log-file it will be much easy to understand your problem.
Jun 26, 2013 | KVH 01 0277 01sl Tracvision A7 Mobile...
Looking for flin flon area azimuth elevation skew angles my dish got moved by a storm and i can't get the signal
You can find the coordinates for Shaw here:
Bell Express View will be different--just Google it.
Mast must be vertical. Elevation is most critical, then azimuth, (direction) then last is skew.
If only the az has been affected (likely if it was just the wind) then turning the dish in very slow increments should eventually find the satellite(s)
Jul 26, 2011 | Televison & Video
Source for stanley plane parts specifically, the knurled set screws that hold the side plate in place on a Stanley #140 skew blade plane
hello. you can order direct from Stanley at
Enjoy your woodworking. Regards, a fellow woodworker, Joe
PS please rate my answer. thank you.
Jan 07, 2010 | Hand Tools
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
KVH M7 track vision problem.Not tracking
as you move east and west on the Mediterranean, you must adjust the LNB, rotate it, see book.
Jul 25, 2009 | KVH 01 0277 01sl Tracvision A7 Mobile...
I need an owners manual for the receiver
What channels on what satellite? You should always start with sat G1 channel 3 and rehit. This will map in all the channels the receiver is authorized to get from Motorola.Options 6 5 and the trip counter should go up by 5 and show ~ 4600 channels
After that you need to make sure you are good on the arc. Start with G-1 5 (analog) then go east about 20 counts to C3 channel 7 On both G1-5 and C3-7 you may need to adjust the skew to get the picture.
The same is true for digital channels like those on G3C like TNT, CNN, SPIKE etc.
Once you know you are on the satellite then adjust the skew.
Feb 22, 2009 | Arris DSR922
I get get digital signals on dsr 922
does the creen say searching for channel? if so you might have to update the maps...go to G! 3 and leave there for about 15 to 20 minutes...make sure you got a dc light....if no you have a tuning with the skew...
Feb 16, 2009 | Arris DSR922
Only picking up one satellite
Thank you for the info.
Here is what you can try:
Try to get the Echo 8.10(110W) first by connecting the LNB on your left if you are behind the dish. On the first transponder from 110W you need to get anything better than 90% quality.
After this is done you may have to play with the skew until you get 119W. On 119W the first transponder frequency is 12239Mhz.
The skew will depend on where you live.
Check here for more info on the parameters to get your dish align.
BTW, What kind of receiver do you have?
Feb 22, 2008 | RCA DISH Network(r) 311 Satellite System
Televison & Video Logo
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
