Question about GE WSXH208A Front Load Washer
Water leaking from the front just below the door
    Genius:
  • 1,075 Answers
You need to get the door seal replaced.adrian,,,
Posted on Jul 28, 2010
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
I just noticed a large pool of water under the duet washer. it is not coming from the supply lines- It only appears when the washer is running. I see it leaking down the side (just above the pedestal). ...
door boot/gasket is bad replace and problem solved.but first take the front panel below door off and make sure before you buy a door boot but if it is leaking you can tell by wipeing finger below door while running usually.
Nov 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Zanussi DS17 slimline dishwasher is leaking from below the door at the front. The inside seals all seem to be fine, but the catchment moulding below the door (which is revealed at the front when the...
Have a look at the bottom spray arm and check the ends of the arm for splitting as this will cause the water to be directed at the door lower section and leak.Try taking arm out and run for a short while and see if it stops the leak.If still no good check that door is closing fully.
Apr 25, 2010 | Dishwashers
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
Leaking water from the front of machine,
Hi
The water level in a front loader should always be below the door line so consequently it should not be possible for water to leak out the door unless there is a problem with the actual door seal itself.
However if you are using too much, or incorrect type of detergent, the washer may be producing too much suds. Too much suds can cause door to leak.
Other causes of a leak which appears to be coming from the front but is on fact coming from elsewhere: Check the water inlet hoses. Check the drain hose. Check the standpipe (upright drain pipe used instead of a sink), or the wash sink connections. These will often be the actual source of a leak. When they leak the water can roll under the washing machine and appear at the front.
Also check this link for a good description of how to troubleshoot leaks happening at various stages during the cycle.
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itleaks
Hope this helps. Thanks for using FixYa.
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
GE WSXH208A Front Load Washer Logo
182 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
