Question about Mitsubishi WS-55807 TV
Unable to get cable channel programmed into set
I moved the set from one house to another, connected the cable input but can only get network channels- the instruction book is lost so I do not know how to get the cable channels into the set's memory.
I moved the set from one house to another and now cant get cable tv and lost remote
Posted on Dec 18, 2008
  • 934 Answers
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Posted on Nov 03, 2008
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
What channel to set for dish network
Depending on the type of cabling your using the input may vary. If you are Connected using a digital cable such as an HDMI or component (y/pb/pr) cable then you want to set the TV to the HDMI or component input by pressing input or source on your TV. If this is connected using coaxial cable tune the TV to channel 60, 62, 73, 75, 3 or 4
Daniel Busa
DISH Network
Customer Service
Apr 21, 2011 | Vizio L32 32 in. LCD HDTV
Hi! My mother gave me an Insignia HDMI TV, and I can't figure out how to hook either my Wii console or Sony DVD player to the TV. I transfered all of the audio/visual cables from the old TV to the new TV...
Hey there!
Is there a button on the set or remote that says "input" or "source"? That will change the input settings from cable, to HDMI or RCA (aux).
Mar 08, 2011 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
mfbmeb,
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
