Question about GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Should there be hot air blowing out from under my refrigerator?
  • dorothy6691 Jul 28, 2010
    It is hot to stand in front of the refrigerator and I thought maybe it was not running efficiently. Thank you.
    Genius:
  • 1,075 Answers
A simple answer is yes,adrian,,,
Posted on Jul 28, 2010
On my my 2003 chysler sebring the ac blows hot air put a whole can of freon in it and it still blows hot air do i need more freon
Have you checked the refrigerant pressure with gauges? If not, do that first. If there is sufficient pressure but you are still getting hot air, your diverter door for your air handler has stopped moving, probably due to an vacuum leak under your dashboard.
Jul 19, 2014 | 2003 Chrysler Sebring
My A/C only blows hot air, but the compressor does click on and off durning the time you have it on. The A/c will blow cool in the night time but not durning the hot part of the day.
When a car a/c is blowing hot air, the refrigerant cannot absorb the heat from the car passenger compartment.
This problem usually cause by a refrigerant leak or a clogged condenser.
If reduction of cold air from a/c system is steady, the possibility is that the refrigerant is slowly leaking out of the hose or seal.
Other reason is a clogged condenser but this is only a contributing factor.
Aug 11, 2010 | 2000 Chevrolet Silverado 1500
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
When i turn ac on air blows hot. the fan is
sounds to me u need to have it recharrged
Oct 03, 2009 | 2004 Infiniti G35 Sport Coupe
2003 Ford Explorer XLT Air Conditioning vents blow hot and cold
It sounds like the control motor switching from hot to cold is stuck halfway in between the two temp settings. You will have to take it down and replace it, it is mounted under dash passenger side near the blower motor.
Sep 09, 2009 | 1996 Ford Explorer
Why does hot air blow out of bottom of Refrigerator
That air out the bottom carries with it the heat that was absorbed from the air inside the box. Consider that heat on your toes as you're grabbing that late-night snack a good thing.
Jul 06, 2009 | Kenmore Refrigerators
Air conditioner on 2002 Pontiac blowing hot air, although freon is not low...also makes a clicking noise.
Take it to a garage and have them evacuate the system and refill with refrigerant. you have air and non condensibles in the refrigerant system.
Jun 02, 2009 | 2002 Pontiac Sunfire
A/c blows hot
Your car is low on refrigerant.
  1. Your system requires R-134A refrigerant which is available at most auto parts stores.
  2. You will also need a hose to connect the refrigerant to the AC system.
  3. You will need to locate the low side AC fitting (looks like a nipple)
  4. With the car running and the AC turned on high, attach the hose to the AC fitting,
  5. attach a can of refrigerant to the other end of the hose.
  6. Turn the screw on the hose to puncture the top of the refrigerant.
  7. Move the can back and forth until the refrigerant is empty.
  8. Detach the hose from the AC system.
Check to see if frost forms on the AC lines under the hood and cool air blowing from the vents inside. If the air isn't cold enough, add another can of refrigerant.
CAUTION: Do not overfill the system. If the system doesn't "**** in" the refrigerant, the compressor needs resetting (disconnect battery 5 min in GM cars and trucks)
I hope this solves your AC issue. All the best!
Greg
May 14, 2009 | 1997 Buick Park Avenue
Whirlpool Gold Refrigerator
When this area gets very hot, it's usually because of inadequate air flow across the condenser coils under the refrigerator. Check to see if the condenser fan has stopped blowing underneath. Remove any obstructions or replace the fan motor if it has stopped. Also clean any accumulation of dust from the coils. The refrigerant line runs down the divider at the front of the unit to warm it slightly and prevent condensation and/or frost there, but it should not be noticeably hot.
Jul 28, 2008 | Whirlpool GD5SHAX Side by Side...
GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
