Question about Bosch WFK 2401
HI. We have a WFK2401 and it has stopped draining.
  • Bosch Master
  • 2,605 Answers
Hello Angelapevans,
Welcome to FixYa.
Based on your description you likely have a clogged drain pump/filter.
Here`s how to check since that would be the first logical place to start.
1) **Turn oiff the power or unplug the cord from the dryer or wall...ehichever applies to your set-up...safety first**
2) Water removal...remove toe panel.
3) Now bleed pump drain...A shallow pan is handy for this step.
3) remove pump filter, but be careful if you don't have a shop-vac or a shallow pan and towels you may get wet...
*Once you`ve gotten to this point you may have trouble removing the filter if it is really plugged up with debris. You might have to wiggle it back and forth as you twist and pull.
4) When you get the filter out, visually inspect inside the pump thoroughly with a flashlight and clean it out really well. It won`t take much to prevent these from draining. i.e. a penny, hair pin, buttons etc.
Let me know if you found anything in the pump and how you make out after that.
If you removed any obstruction, simply reassemble the unit making sure the filter is screwed in tight, run a quick rinse cycle to test for leaks before putting the toe panel back on and you should be good to go...save for any leaks.
There are other possible factors that can prevent the unit from draining or spinning out items properly, but we`ll cross that bridge when and if we get there.
Thank you for choosing FixYa, keep me posted on your situation.
macmarkus :)
Posted on Jul 28, 2010
  • Mark MacDonald
    Mark MacDonald Jul 28, 2010
    It appears the photos I attached didn`t appear, let me try again. They should have appears as follows...
    1) Toe panel...
    2) Identify pump bleed tube...
    3) Bleed water from pump...
    4) Pump filter remove...turn counter-clockwise.
    Sorry about that first attempt. I`m not sure what happened.
    macmarkus :)
My Bosch WFK2401 washer has stopped filling. The cycle will count down and the pump will run to drain (but nothing to drain!). I have checked the supply lines, there is water and the filter screens are...
I suspect the solenoid on the water input connection has failed, this is the unit that allows water into the machine , if you know a bit open the lid and you should see this just inside behind the cold water connection.
Oct 20, 2013 | Bosch WFK 2401
I have a WFK2401 Bosch washing machine it is not spinning the clothes dry but the water drains from the machine. I did clean out the pump and trap but it is still not working. What do you think it is?
WFK2401 Bosch washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 21, 2011 | Bosch WFK 2401
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
I have a bosch washer model wfk2401. i cannot get
door lock mechanism must have jammed in open position. unless the door gets locked, the wash cycle would not start. check the electrical connection in the door lock and physically verify the lock operates when commanded
Mar 19, 2010 | Washing Machines
Bosch WFK2401 won't start error code 6
Open the panel at the bottom using a 2p coin by turning clockwise
Pull the rubber hose out of the holder and drain water into a container until stops
turn large plastic screw to the left for access to the pump
Clear away and debris bits of metal, plastic, etc that has stopped the pump.
Opposite of above to reassemble
Switch on and test... good luck!
Mar 23, 2009 | Bosch WFK 2401
My bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Mar 04, 2009 | Bosch WFK 2401
Bosch WFK2401 Drain Pump
I have a WFL 2060 UC on the bottom right there is a small access door. Inside the door you will find a drain plug which will unscrew counter clock wise. Water will come out so I tipped up the machine and slid a 1" deep cooking pan under the corner. When I unscrewed the plug I found a penny inside.
Aug 24, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
