Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Grindind sound on carpet setting
When the setting is placed on carpet the brush does not rotate and makes a loud grinding sound. there are no obstructionss, the belt is not broken and there is nothing caught in the brush.
    Problem Solver:
  • 7 Answers
My also does this but it subsides, call dyson i think it would be warranty work
Posted on Aug 08, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
If the belt is still connected to the brush and it is tight then the motor has gone wrong depending on how old the machine is you could take it back if not a repair is the only option
Posted on Jul 29, 2010
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
Making a loud sound
could be that the clutch is bad or the brush roll needs to be removed, cleaned, ends removed and lubed. Try to spin the brush roll and see if it moves freely...if not, it needs to be cleaned and lubed at both ends. I fixed mine today by doing this...not an easy task to remove the brush roll, but it can be done:)
Mar 17, 2013 | Miele S7210 S7 Series Twist Upright Vacuum...
My Bissell Pet Eraser brush only rotating on the bare floor setting, when on the pet setting, it won't rotate. What is the problem? Thanks.
it sounds like something is backwards. the brush should only rotate when using it on carpet, it should never rotate on the bare floors. check the belt for propper installation
Jan 03, 2010 | Bissell Upright Vacuum - The Pet Hair...
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Dec 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hello. I took the sole plate of to clean the brushes on my dyson dc14 however the brush part came out and i put it back in but since then whenever i switch it over to carpet setting it makes this really...
You really need to take the sole plate back off and make sure the belt is running exactly where it's supposed to go and not looped over a piece of plastic or anything. More important is that you make sure the ends of the brush are seated properly and the bearings the brush is mounted to are clean and rotate freely. Look at each component and make sure they are assembled perfectly. Make sure a plastic ring or piece that goes on the end of the brush didn't get dropped under a piece of furniture and you forgot about it. If the problem keeps happening, take the brush and belt back out and carefully turn the machine on to see if it makes the sound. If it doesn't make the sound with the brush out, the problem is with the brush assembly. If it does make the sound, the clutch that turn the brush on and off is damaged and needs to be replaced. You can order a new clutch assembly and replace it without much trouble. They want you to think you can switch between floor and carpet settings all the time but it's really really stressful on that clutch to switch between settings with the motor running. Think about how powerful that motor is. Think about the poor unassuming brush assembly being jerked to life by that powerful motor running at full speed. I've seen that destroy a clutch in about two years. Anyway, it's much better for the life of your dyson to turn the motor off when you switch to carpet mode (when you turn the brushes on). You probably don't have to bother turning off the motor when turning the brushes off, or switching to bare floor mode, because it's not that stressful on the mechanism to just disengage the running motor.
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Less than normal or no pickup from cleanerhead
These are not real powerfull vacuums (I know not what you have heard) but make sure bottom plate is fully sealed I see customers put these on wrong and the brush does not make good contact
Nov 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
182 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
