Question about Gateway E-6100-C PC Desktop
Mouse keyboard and video are not working. I have changed the motherboard and power supply and still having the same issue
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 59 Answers
First of all you update your drivers ,,,,,,
it seems that there is problem with your mouse and keyboard connector ,check those things ,,,,,,,,,,,,,
Posted on Jul 28, 2010
Gateway DX-4831
sounds to be a bad motherboard
Jun 24, 2017 | Computers & Internet
Ga-g41mt-s2p onboard video not working
Remove ram memory one at a time to rule out issues, if video graphics card can be disconnected do it to see if any change in beep codes, do the same with the remainder of the hardware such as the hard drive and additional parts. My sense is the motherboard is bad, but you need to be sure as much as possible.
Mar 03, 2012 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Why wont the mouse,keyboard and monitor not work after cpu,pwer supply install...
If the motherboard used to work with the old cpu and power supply, but does not with the new cpu and power supply, then probably the cpu or power supply is bad.
Why did you change the cpu and power supply?
If the power supply went bad, it could have overloaded the mother board as well as the old cpu.
If you think the old cpu went bad, how do you know it was not actually the motherboard that went bad?
All I can suggest is that you double check all the connections.
If you have USB mouse and keyboard, try a DIN connected pair.
If you are using the onboard graphics, try a PCI express card instead.
Tell us if there is any front light activity from the power switch, drive, etc.?
Dec 21, 2010 | Biostar P4M900-M4 Motherboard
HP dv2000 fails when power supply connected
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Jan 04, 2010 | HP Pavilion dv2000 Series Laptop Full...
Long beep continously
One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU OverheatingOR Continuous beep Power supply, system board, or keyboard problem
Jul 13, 2009 | Soltek SL-75FRN2-L Motherboard
No video mouse or keyboard but all power and leds are working
there are several problems to this case.
1. check the 24 pin power supply and be sure to plugin the 4 pin power supply just beside the cpu.
2.ram not placed correctly
3.Power supply inefficient.
4.BAD BIOS SETTINGS Try resetting bios i.e.., CLEAR CMOS or remove onboard battery, wait for a while and then place it again.
5.RAM is damaged
6. Highly overclocked cpu - resetting bios works
Check all the above to see whether your computer comes online.
6.
Apr 22, 2009 | ASUS P5GC-MX/1333 Motherboard
Acer aspire laptop mouse and keyboard not working
  1. first check the bios.
  2. you can use serial mouse or keyboard change this parallel mouse and keyboard.
Mar 29, 2009 | ASUS P5PE-VM Motherboard
On first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Problem with a dell computer..
You may try connecting a different usb keyboard to your system. Mostly, some keyboard converted from serial connection to a usb could cause this kind of problem. In some cases also, wireless keyboard and mouse won't work when u turned on your system if the driver is not properly install.
You may also try disconnecting any other usb devices from your computer. Disconnect also your power supply then push and hold the power button for 5 seconds. Plug back in the power cord then connect your keyboard. Turn on your computer. if it doesn't work, i suggest to call your computer manufacturer and check your warranty. This could be an issue with the motherboard of your computer.
Keep me posted.
Thanks.
Jeff
Oct 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
One problem, followed by another, followed by another
it seams that the motherboard has some power problems. Check on the motherboard for burned or blackened components, or for capacitors that are looking like they are going to blow (inflated on the top), u can do the same to the power supply.
If so change it !
Also maybe the power of the house has problems that the computers power supply cant handle (that can ruin the motherboard or other components )
U can also try to isolate the motherboard from the case (there might be a short between the motherboard and the power supply through the case metal ... )
Jan 20, 2008 | EliteGroup L7VMM2 Motherboard
Gateway E-6100-C PC Desktop Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
