Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE D52GW12 52'' HDTV POWER SUPPLY OUT
Power supply went out
  • GE Master
  • 8,617 Answers
You can get any replacement board that you require for your model from www.tvrepairworld.com they will also help you determine which board is correct for your model and symptoms.
Posted on Jul 29, 2010
Power went out wont turn on
The power supply board has a fuse on it, with any luck it's just the fuse. Others have problems with the capacitors on the board.
Google lg 42lc2d power supply board for info a boards for sell if needed.
May 27, 2014 | LG 42LC2D 42 in. LCD HDTV
Samsung ft-p5084 plaza tv went blank. No power at all.
If that fuse is blown chances are its because the Power supply has developed a short. The power supply will need replacement. You can easially install a power supply yourself just a few screws and couple of wire sockets and the old board pops right out. You can get the power boards from www.tvcircuitboards.com
Feb 09, 2013 | Samsung FPT5084 50 in. Plasma HDTV
Vizio hdtv went POP then black while watching a program. Reset did not help.
sounds like a power supply failure open the unit and inspect the power supply for any damage type bad capacitor into google and look for any bad caps on ur power supply
replace them
if all else fails replace the power supply
please make sure to disconnect your tv from the mains and wait at least half an hour before doing any kind of work to it as it may still hold a charge that could harm you
May 15, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
Have Ge model 52GW945 tv, it went blank no picture, nothing, I checked fuse its ok what next
Check the swithed mode power supply section. Some sets uses Ics for control the power regulation, while others uses transistors as oscillators and choppers. If the power to the oscillator section of the SMPS is absent, the supply system won't wake up. So many reasons are there. You just check the resistor, usually connected from main DC rectified supply, to energise the oscillator section of the SMPS. In most sets it may be two resistors in serial, usually 270k 1W*2. If any one of this get opened, the power supply will not start up. Check it first and preceed. If the set uses Ic as regulator controller, check the positive supply voltage at the respective pin of the Ic.
Oct 15, 2010 | GE Televison & Video
Our power went out and when it came back on the tv didn't
The power supply board is dead,that the board where the power a/c cord go into it.Replaced the power supply board will get ur tv power back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 07, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Own a 52" panasonic rear projection tv. Heard a loud pop, and tv went out. Will not turn back on.
Power supply board is dead.Replaced power supply will solved this problem.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to replaced.
Feb 25, 2010 | Panasonic PT-53TW53 53" Rear Projection...
32" TV no power.
This question has been answered:
http://www.fixya.com/support/t362706-westinghouse_lcd_tv_parts
it is Delta Electronics DPS-210EP-2 C power supply board
this company can repair: http://www.power-supply-repair.com/
Oct 24, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Hi I have an LG LCD tv and this morning it just went dead, as if there is no power getting to it at all. The electric supply is ok Regards BMcD
If it is completely dead (no standby light, flashing LED blinks), the power supply failed. Replace the Power Supply board to fix.
Oct 05, 2009 | LG 37LC7D 37 in. LCD HDTV
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Apr 08, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
800 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
