Question about Samsung Touch of Color LN52A650 52 in. LCD HDTV
I have a 52A650 and the TV shut off and turns on several times before it stays on the the night.
  • Samsung Master
  • 8,457 Answers
The tv now flashes it power light indication's alot?Turn off/no at least 4 or 5 to turn on tv now?Tv power supply board,that the board,where the power a/c cord plug into it.That the power supply board have problems and dying,must be replaced.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jul 28, 2010
Recently replaced the power supply unit in my 47LD450-UA tv. It was turning turning for a few minutes then would turn off and not come on. After replacing the power supply unit, it stayed on long en
Your original problem of failed electrolytic capacitors (common) may be the same one occurring in the replacement if it was a 'pull' from another set.
Normally, depending on the quality of the parts used, these supplies will survive for several years before failing.
If this was in fact removed from another set, it's time to return it if there was any kind of warranty.
If not, the repair cost isn't that great if you have an honest tech in your area.
Jan 09, 2015 | LG 47LD450 47 in. TV
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have SAMSUNG HL-S5087W that sometime shuts off several times a night. And sometimes not at all. Heard there is specific part that is not very hard to change. Any help out there?
Yes,it is the tv projection lamp.When it is shutting down several times.The LED "LAMP" light indication flashes or stay on.That the indication the projection lamp life are ending or near the end.Require a new tv projection lamp.
Dec 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
The Television will not stay on
LOOKS LIKE YOUR CONVEGENCE IC ARE SHORT UNWELD BOTH IC AND TURN TV ON IF IT STAYS ON 450 DOLLASR TO REPAIR
Jun 03, 2010 | Hitachi 43F300 43" Rear Projection...
It stays on for a different length of time each time it's turned on. Sometimes will work for many hours per night and 4 or 5 nights, sometimes will stay on for only a few minutes. When it shuts down, you...
This tv is aging and you many bad grounds on the deflection board [it has the flyback transformer] And many bad grounds on the signal module [has convergence ICs]. And many many bad capacitors..I know as I repaired a few of these.
Nov 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Westinghouse 32" TV randomly shuts off
It is a good possibility that you have 1 of your inverter transformers going bad. I wouldn't wait to have it looked at. It can cause more damage if the bad one let's go all together.
Oct 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sony 36xbr800 shuts off on own
sounds like one of your color tubes or a system board is failing and will have to be tested and replaced by repairman
Feb 11, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Samsung Touch of Color LN52A650 52 in. LCD HDTV Logo
145 people viewed this question
Jerry Greenberg
Jerry Greenberg
