Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Is only selectively printing some of the text, but not the majority, especially black
    Brigadier General:
  • 3,917 Answers
Hi
It sounds like the print head black portion might be gummed up. Pop out the print head, and clean it using the alcohol solution. You may also want to force some of the alcohol solution through the nozzles. After, submerse it in warm water for five minutes, blot it dry and use some q-tips to dry around the nozzles. Let it sit for ten minutes or so to be sure it is dry, and then pop it back in the printer with some new ink cartridges. You may need to run through a cleaning and deep cleaning after this process too.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 28, 2010
Is there any way to continue to print in BLACK AND WHITE when he colored ink has run out...((5 of the time I print in B&W
I'm afraid not. Most colour printers print what is known as 4 colour black to give a deeper more solid black, so all the coloured inks as well as black are needed to print a black text or image.
Apr 15, 2014 | HP Office Equipment & Supplies
How to print from the internet in Black and white and not colour
Click Ctrl+P Keys, then select the printer, select preference, select imaging tab, then go to grayscale settings check the print text as black & print graphics as black check box.
Apr 23, 2011 | Office Equipment & Supplies
My Lexmark T640 prints out white text and black background instead of black text on white paper
Go to control panel select printers and then select lexmark left click and open printing preferences select graphics tab and uncheck the negative box, the printing will be normal from now on.
Jun 04, 2010 | Lexmark T640 Laser Printer
Cannot print emailed air confirmation page -- when I select print, the only thing printed is the top line, e.g., United airlines, but not the reservation information. After that first one line, only...
Copy the text into the NOTEPAD application, to remove all text-formatting & text-colouring, e.g., "white" text over a "black" background will become "black" text over a "plain" background.
May 07, 2010 | HP Photosmart C4580 All-in-One - InkJet...
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
