Question about Maytag MSD2756G Side by Side Refrigerator
Door does not shut
I removed the doors & now i put it back on but the door does not shut i have a maytag side by side msd275g
    President:
  • 1,099 Answers
down at the bottom corner close to the henge side . watch it as you close the door . now if you have one of those screwdrivers that you change the bit in . and i think everyone has one . but that will fit on the nut head screw . loosen them up along the bottom and up bout half way up the side . then push the seal out from the corner then tighten them back up . now dont take those ****** all the way out .
Also note that
You may need to adjust the hinges, mainly the top hinge, look under the plastic plate there are usually three screws, they may be loose or they may need to be slid back.
Good luck
Posted on Jul 28, 2010
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    MSD2754GR FRIDGE SID DOES NOT GET COLD OR SHUT ALL THE WAY UNTIL YOU LIFT UP THE FRIDGE SIDE AND SHUT. CAN I FIX THIS BY PUTTING A WASHER AT THE BOTTOME OF THE DORR OR IS THERE TOO MUCH ON THE DOOR AS MY...
    The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
    Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
    Jun 01, 2011 | Maytag MSD2456G Side by Side Refrigerator
    The passanger door on a 2006 mustang gt convertable was pushed forward and when u open the door it catches the front quarter pannel. So I need to move it back a little bit so it does not catch. ??
    take a small piece of wood 1"x 3" x about 4" long and place inside door jam at hinge , slowly close door until it puts pressure on wood,... push door shut gently and remove wood and try shutting door , this is what they call redneck auto body. to do it right you will need to remove hinge and add washers to back side of hinge plate so it moves hinge out thus pushing door alignment back if hinge is welded on add washers to door side where hinges attach to door.
    Apr 04, 2011 | Ford Mustang Cars & Trucks
    My maytag neptune is locked... will not start... will not unlock... code nd??? can you help.. i tryed to unplug. reset . nothing
    To unlock the door, follow these instructions: 1) unplug the power cord 2) shut off all water connections and remove hoses from source.
    3) unscrew the metal access panel on the back side of the touch pad console on the back/top of the unit.
    4) unplug the white, three pin connector(red, blue, & yellow wires that are in this order from left-to-right when looking from the back of the washer to the front)
    5) plug the power cord into the wall receptacle
    6) press the "delicates" & "heavy soil" buttons at the same time for 3 seconds(this puts the unit into the "service mode"
    7) press the "extra rinse" button(this will UNLOCK the door Note: I am sending this to MAYTAG as well, although they and their lousy service system and their authorized service affiliates would not even think of offering such emergency help on any web site ....xkellyx
    Nov 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Refrigerator side does not get cold. Freezer sid eworks fine, but no air or getting cold on the other side.
    clean up the back, where the compressor is located and might need some freon.
    the doors might not be closing properly.
    Jul 08, 2009 | Maytag MSD2656G Side by Side Refrigerator
    Need to replace my Maytag the door is reverseable. Who makes those now?
    The doors are reversabe they go from left hand open to right hand open. Just reverse the hinges, put the door fillers ( triangle shape go toward the front. Remove the plug put it in the other sidel. Now take the metal door strke and put it on the other side, Then take the filler from on side and put it on the other side. Takes 10 to 15 minutes to make the change.
    No need to purchase another door!
    Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Freezer side door opens when large refrgerator door is closed
    no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
    Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
    Maytag frig side by side door pops open when I shut the other side
    the ref. is not level or too much wieght in the freshfood door
    If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
    Jun 03, 2008 | Refrigerators
    Maytag MSD2756G Side by Side Refrigerator Logo
    157 people viewed this question
    Top Maytag Refrigerators Experts
    Marvin
    Marvin
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
