Turn off afer 3 second - Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
Check ur cable connections
Posted on Jul 28, 2010
T & C 2001 REMOTE CONTROL PROGRAMMING
ATTENTION: You MUST HAVE one working remote to add one more to the system.
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. A chime will sound afer each
additional remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Sep 17, 2012 | 2001 Chrysler Town & Country
While the engine quit and afer sittin for a short time started and went about 1 mile and engin died again. It wasn't overheating
without further diagnosis and proper testing equipment it sounds like you have a bad ignition coil or possibly a bad fuel pump. remove the fuel filler cap when this happens and listen for the fuel pump to come on when you turn the key to the run position. the fuel pump should run for 3-5 seconds. if it does the ignition coil is probably bad as the windings inside the coil can seperate when hot and reconnect when they cool again. good luck
Sep 23, 2010 | 1994 Ford Econoline
When i turn on my microwave it cuts out afer a couple of seconds and displays H 95, john thanks
Please check your TCO- thermal cut out sensor mounted on the cavity . If this senses a higherr thermal point it might cut off.
Also check on the main capacitor or if the magnetron is faulty.
Helpful?
Aug 25, 2010 | Neff Microwave Ovens
It shuts off afer 5 seconds when powered on.
Does the unit output sound when powered on? If no sound can be heard, and you only hear a click after 5 sec. then your power circuit may have a faulty diode.
Apr 02, 2010 | Sherwood RD-6500 Receiver
I have a maytag DC68-02031A clothes dryer. When I
E 3 is not a maytag fault code . may be f 3 . I need your model & ser # and I can tell you more . thams mm
Nov 20, 2009 | Refrigerators
Technics S600 Mk 3 Amplifier suffering cut out afer approx
sounds as if amp is clipping.do you have the gain hi, turn it down.are the amps getting good air.are they drawing alot of power from batt alt...do the big 3.
Sep 04, 2009 | Audio Players & Recorders
I bought a second wii remote it is fully charged but it flashes several blue lights then switches itself off! please help
wen you go to play a muliplayer game and the second remote won't turn on automatically wen a button is pressed then with the player one remote go onto the wii menu then go onto wii remote settings ( at the bottom of the screen) then click on reconnect press 1 and 2 at the same time on the player one remote after a while it will turn on the do the same thing with the player 2 remote and it should turn on afer a few seconds
hope that helps =]
Apr 23, 2009 | Nintendo Wii Remote Controller
Xbox 360
Just contact the fixing microsoft company because there is no other way but it may cost you some mulla
Mar 25, 2008 | Microsoft Xbox 360 Console
APC Smart-UPS 1000VA is powered on but not working
Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
Computers & Internet Logo
105 people viewed this question
Alun Cox
David Payne
David Payne
