Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
The disposal is leaking at the bottom of the unit through the housing. No leaks at plumbing connections just through the bottom. thank you jack
  • nwww1 Aug 20, 2010
    how old is the unit and there should be a phone number to call for warrany work if it is with in the warranty period, Insinkerator has contracts with local service people to take care of there problem's. I think its just wore out .
    Problem Solver:
  • 5 Answers
Seal is gone, buy new one
Posted on Sep 03, 2010
Disosal leaking from bottom but also is backing water in Dishwasher when not being used.
A person familiar with plumbing needs to check your dishwasher and disposal and pipes that are connected with both of these.
To me it sounds like you have a blockage somewhere, could even be in the pipes, not the disposal or the dishwasher.
The leak of the disposal could be the disposal leaking or the plumbing pipes leaking.
God bless your efforts.
Nov 23, 2017 | Dishwashers
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
The unit works, but if the water level gets too high, while operating, it begins to drip from the bottom of the unit. Nothing on the exterior is wet. Can it be fixed, or should I replace it? Where can I...
Where is leak coming from?
From the pipes or from bottom of disposal?
If leak is coming from tubular drain pipe or around dishwasher connection, then clean out disposal and repair connections.
If leak is at bottom of disposal, then disposal is probably rusted out and needs replacement.
To solve high water issue and leaking pipes.
Loosen 2 nuts on P-trap and trap falls loose. Then remove tailpiece that connects to side of disposal. Hang rag over opening on side of disposal so water is directed downward, then turn on water and disposal and flush out the clog. Clean trap and tubular drain, and then reassemble.
I wrote ez disposal replacement steps, that also show how to take apart and reassemble tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal is leaking at bottom out of the body... No leaks in plumbing or outside of the body
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Aug 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is dripping out of the bottom of my kitchenaid kadette 250 1/2 HP disposal. Is there a fix?
If the leak is coming from the bottom of the disposal check the sink connection, drain connection, and housing gasket. If you find these are all good and you can see the water is definitely coming from the disposal itself and not from any of these connections, then the internal seal in the disposal is bad and will need to be replaced. If the disposal is over a few years old then it is more than likely best to just replace the unit. Not cost effective to have it repaired.
Jun 07, 2010 | KitchenAid KSU90S0MLL 16" Undermount...
My insinkerator Badger 5 is leaking from the bottom. It runs, but water runs out of all spots on the bottom; including the ara where the conduit runs into the unit - please help!
My bet is that the garbage disposal in not what is leaking... the connection to the bottom of the sink is leaking and running down the sides of the disposer...
Look higher and you will find your leak..
How is the best way to use a Garbage Disposal
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
heatman101
May 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking
first check and make sure that the water is not leaking from the hose connection to the dishwasher or the drain fitting itself. If neither of these is the problem and it is definetly leaking from the housing then replace. I recommend the Badger series disposal with a 5 or 7 tear warranty I have installed them for years and never had a single problem.
Jul 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
May 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher leaking at the bottom of the door during operation.
hi If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
thanks....................
Sep 12, 2008 | Whirlpool Dishwashers
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
424 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
