Question about Whirlpool LSR5132PQ Top Load Washer
I have a whirlpool washer model # LSR8444LQ1. The motor runs but the tub does not move
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
SOURCE: Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Posted on Feb 03, 2008
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 185 Answers
SOURCE: roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Posted on Mar 26, 2008
Krazytech
  • 725 Answers
SOURCE: I have a Whirlpool washer,
Sounds like you have a bad brake & Drive tube (spin tube) the brake may not be ingaging or the ear are broken off the tube ( you can check this just remove the agitaator and you can check the ears)
let me know if you find out ,,
Posted on Sep 20, 2008
Washing section does not turn, but motor is running.
This really depends on brand and model of washer. Some washers have a belt, so belt could be bad. Others have a coupling that goes between the motor and transmission, so that could be broke. Also, something could be wedged between the tub and outter tub, keeping the tub from moving. First, see if you can turn tub with your hand and then move on from there.
May 25, 2016 | Washing Machines
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Estate Whirlpool Washer, model #TAWS850PQ0 fills the tub but does nothing else. It does not agitate or spin, just hums.
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
May 24, 2009 | Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Washer will not empty
sounds like coupler is out but unit should still drain unless motor locked. remove cabinet (2 brass clips under console) and check pump (up front) and coupler (behind motor). set to spin and tub wont move with coupler out but pump will run
Apr 05, 2009 | Whirlpool Inglis IP4400 Washer
Washer tub will not move on any setting
SOUNDS LIKE A BROKEN COUPLER, YOU WILL FIND THIS BETWEEN MOTOR & TRANSMISSION.
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
165 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
