Question about Brother HL 1240 Printer
The alarm button keeps blinking. How do I get it to stop?
  • 73 Answers
Well I'm sure that the alarm button is blinking for a reason. I beleive that printer is a laser so unless you dont have paper in it :)
You most likely are low on toner or need to change the drum.
Posted on Jul 28, 2010
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Blinkers ( both sides ) blink a couple times and stop on 2001 VW New Beetle
ALARM BUTTON FAULTY.REPLACE IT.IT HAS THE RELAY FOR THE BLINKERS INSIDE!!!!!SO SIMPLE!!!IF THEY DONT WORK SMACK THE ALARM BUTTON!!THEY WILL WORK FOR A WHILE!!!
Mar 22, 2014 | 2006 Volkswagen New Beetle
There is a blinking red led light under lower left side of driver and steering wheel attached to dash. It blinks ALWAYs!!!
This is most likely your "Valet" alarm disable switch. Use to disable your car alarm so you can keep your Alarm Fob and let a Valet, mechanic, friend etc. operate the car without the alarm being functional. If it is an after market alarm, consult the mfg's manual, if OEM contact dealer for operating instructions.
Jun 30, 2013 | 2004 Hyundai Tiburon
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Car alarm
Try this:
1.Get in the car
2. Closw the door
3. Disable the alarm sensor
4. Activate the alarm
5. Wait 30-35 sec
6. Get out of the car
7. Stop the alaram
8. Get in the car
9. Put the key on the position II, without starting the engine
10. Push the button READ
The alarm led must blink. Then you alarm is reset.
Sorry but my english is not very good, i'm from Romania, i hope you understand
Aug 08, 2008 | 2002 Volvo S60
7-4837B clock radio
Press the Cancel button. While the wake mode LED is blinking (either alarm or radio) press the Wake Mode button. The wake mode LED should now be off. To turn off the Nap function before the alarm sounds, press and hold the Nap button for 3-5 seconds. The Nap LED should stop blinking and be off.
Jul 15, 2008 | GE 74897 Clock Radio
Setting watch
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
Mar 25, 2008 | Timex 1440 Nylon watch
ALARM!
make sure printer connect to power source/cable power then
press power button while press stop button,release stop button while still press power button.
press stop button twice and release.
after power button stop blink press stop/resume four times then turn off printer.
Mar 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Brother HL 1240 Printer Logo
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
