Refrigerators Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keeps running,whole fridge turning into a freezer.Changed thermostat with no change
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Jul 28, 2010
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
683772
Points
8555
Check the electronic defrost control. Also check the damper door, if equipped. The unit will have to be unplugged and defrosted, then the defrost control board will have to be replaced. Since I don't have a model number, I don't know your setup. Sometimes the defrost control is on the main control board. Good luck, and hope this helps.
  • 1 more comment
  • scratchdocto Jul 28, 2010
    Model MCBR415SF, small fridge approx. 4 yrs old. There is no defrost,just turn to 0 to turn off.I cannot take any panels off the fridge.they blew insulation in when wet and dried to outer panels like concrete.According to schematic.Runs from main power to door switch for light to thermostat to overload protector to solenoid to starter switch for compressor.The fridge is up North so Im going off the top of my head,so I think that was the order.
    Mike
    Mike here again,I forgot to mention the fridge was in a trailer.Who ever installed it,packed the back with insulation.Obviously overheating it.Thats when the problem started.
  • scratchdocto Jul 29, 2010
    Do u hav an answer or do I need to look elsewhere?
    Mike
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
The temperature is to low in my freezer
If you have already tried the thermostat either in the fridge part or on the outside and it doesn't change the thermostat may need changing as if it doesn't tell the compressor to stop making it cold, then the whole freezer just keeps getting colder until the compressor breaks.
Try the thrmostat and if it doesn't work get a service engineer out to fix it.
Shouldn't be too expensive.
GOOD LUCK
2helpful
I have a 30 year old fridgidere top freezer refridgerator and the fan in the freezer keeps stopping first it sounds like it is hitting something then it stops and if I turn off the fridge for a day and...
This is a pure case of the AUTO DEFROST timer having a fault or the THERMOSTAT being weak.
The fan is hitting onthe frost that is building up after a couple of days.When you shut the fridge all frost goes off to clear the fan , the frost then build up gradually as the timer does not activate the auto defrost or the thermostat is cutting off the fridge as it runs on.
So get these two parts checked and changed. Inthe first place ccheck the timerr, normally at the rear bottom.
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
4helpful
2answers
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Whirlpool top freezer bottom fridge
check if compressor is running if no check thermostat , bypass thermostat if comp starts change thermostat. if comp does not start call repair man as comp will have to be changed, major operation.
If comp is running OK then check evap fan motor
3helpful
4answers
Freezer icing up
I changed the defrost thermostat and it solved the problem.
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
