Question about Kenmore Washing Machines
Spin cycle doesn't remove all the water during normal wash, return to spin cycle and second spin removes all the water,
    Brigadier General:
  • 3,917 Answers
Hi
Please check the link bellow…if it helps..
http://www.ehow.com/how_5844799_troubleshoot-drain-during-spin-cycle.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 28, 2010
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Standing water in base of washing machine
Is it a front load machine? If so, remove the kick plate under the door and there should be a plastic filter that screws in on your right (approx 2"-3" in diameter). You'll need a catch pan that's lower than the bottom edge of the filter cap, as water will flow out of it when removed. I had one that would occasionally eat a sock or other small article of clothing, stopping up the drain filter and causing the tub to hold water. The added weight of the water causes the tub to not turn at the RPMs needed, and sometimes not at all. Let me know if this helps.
Apr 27, 2012 | GE Washing Machines
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water will not fill during rinse cycle water just keeps runningg?
That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Washing Machines Logo
12 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
