Question about Dometic Rooftop RV Air Conditioner
Fan runs but dosnt blow cold air - Dometic Rooftop RV Air Conditioner
  • 674 Answers
You need to check the condenser fan and compressor to see if they are running. Check any fuses or breakers for them. If the breakers/fuses are good then check the contactor. If that's ok the check the capacitor(s) for them. Let me know what you find.
Posted on Jul 28, 2010
Why is it blowing warm air?
U say the compressor fan is running. How about the compressor - is that running? Without the latter running there is no way you will ever get cold air!
Check for bad start cap/start relay.
Sep 21, 2015 | Heating & Cooling
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
I have a split system air conditioner that quit blowing cold air
either the compressor is not running or you have a leak and are low on freon. the outside fan running does not tell you the compressor is running.
Jun 18, 2014 | Coleman Outdoor Split System Air...
I have a 97 town and country with a 3.8 i have charged the ac and the coressor kicks on but the fans on the radiator dont and it dosnt blow out any cold air the ac lines dont even get cold can it be that...
If it doesn't cool at all there is a fault in the system preventing it from cooling down properly and building pressure like it should. You will need to have this checked by a service tech.
Jun 17, 2010 | 1997 Chrysler Town & Country
Freezer gets cold fan dont work fridge dosnt get cold
The fridge relies on the freezer fan to supply it's air flow. If the unit is running and the freezer fan is not, then most likely it is the evaporator fan motor that has failed. You can access it by removing the inside back wall of the freezer. If you need help get me the complete model number out of the fridge and I can pull up the breakdown to help walk you through it.
Jun 14, 2010 | Kenmore 65802
The last time i used my ac here in las vegas nv. was july 2009 and it was freezing. i terned it on to check to see if it still blew cold and it dosnt. blows air fine but dosnt get cold, is there a re-set...
central air or window unit? central systems use a low/high pressure limit switches which self reset when pressures are nominal. suction about 50-60, high pressures around 300.
Oct 20, 2009 | Heating & Cooling
Blower motor not working any speed
Check for the busted fuse at the fusebox labelled
Fan. Hope this help.
Sep 23, 2009 | 2001 BMW 325
Heater won,t blow warm . core ok. fan runs .will only blow cold
EITHER VALVE STUCK TO ALLOW WATER IN MATRIX OR YOU HAVE AIR BLOCK IN IT. TAKE OFF TOP HOSE AND RUN MOTOR, TOP UP RAD AT SAME TIME, USED A DESCALANT IF WATER MUDDY /RUSTY LOOKING
Feb 02, 2009 | 1997 Dodge Neon
Cold air in cab
Check to see if your coolant is low. If its too low, it cant be pumped to the heater fan.
Jan 27, 2009 | 2000 Chevrolet Silverado 1500
Dometic Rooftop RV Air Conditioner Logo
216 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
