My Magnavox Model ID 15MF150V/37 has a picture but does not have sound. Also, sometimes the picture has hues of pink on the left side of the screen.
5 Suggested Answers
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
  • 50 Answers
SOURCE: philips 37 flat screen
I'VE WORKED ON A LOT OF PHILIPS FLAT SCREENS AND ALWAYS NOTE ,WHEN THERE ARE PROBLEMS WITH THESE SETS--THE RED LED WILL BLINK GIVEN YOU A CODE FOR TROUBLESHOOTING..EXAMPLE---ONE L0NG BLINK,4 QUICK BLINKS--BAD AUDIO BOARD,,,SOOOOOOOOOOO,CHECK YOUR BLINKS,HA!
Posted on Mar 21, 2008
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
stonephoenix
  • 563 Answers
SOURCE: magnavox 42mf230a/37 turns on but no picture or
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're under warranty or you purchased an extended warranty or service plan, the repair costs will be covered.
If you're not in warranty you'll have to pay for the repair. The cost would likely be a minimum of $300+ for parts and labor. The circuit boards in these new LCDs are not cheap at all! I've seen repair costs averaging $450 and up for large LCD TVs.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
The screen gets pink contrast only on the right side of the screen. The left side of the picture will be perfectly clear and the right side has pink hue. What could cause this and how can I fix it?
could be a panel driver (if it looks like lines) or just poor digital connection(most of the time) could be in the tv (the connector is faulty) or your cable.
Apr 08, 2010 | Insignia IS-LCDTV32 32 in. Television
Turn tv on no sound
You have a bad filter capacitor! In a dark room, powerup your TV and shine a flashlight on the screen. Can you see a picture? Sometimes the power inverter is not powering up. And sometimes you will see a picture with your flashlight. But chances are you will need a 25volt 2200MF Cap replaced!
Feb 11, 2010 | Philips Magnavox 42MF521D/37 Television
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
No picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Jan 13, 2010 | Philips Magnavox 42MF521D/37 Television
Powers on but no picture or sound
i need a screen off a 47inch magnavox if u coudent fix urs and ur interested in selling me ur screen let me know
(47mf437b/37) noe28cervantes@yahoo.com
Jan 04, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
When sound & picture finally comes on the picture is pink and in the middle of the screen
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the no audio/video and video shrinking problem.
Sep 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
