Question about Sony VAIO VGN-TXN25N/B PC Notebook
Vaio VGN-TXN25N, need to remove hard drive
I want to remove the hard drive. I've removed the battery and have removed 8 screws from the bottom - every screw that had a little arrow pointing to it.
I thought the next step would be to lift either the keyboard or separate the case. The case won't quite separate. I found tabs and removed the keyboard (the ribbon came out with it), but still don't see how to get to the hard drive.
Advice please?
  • Adena K Apr 24, 2008
    Thanks for trying. I already looked in the obvious places. It is not easily accessible by simply removing a cover from the frame.
  • flybone10 Apr 30, 2009
    I recieved a criptic message from my viao VGN-TXN25N predicting an imminent hard drive failure. I would like to swap out the drive but because of Sony's engenering I can't get it out. Please help
  • 176 Answers
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Posted on Apr 24, 2008
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Remove touch pad on vgn-cs100
It might be easier to just replace the whole Palmrest that comes with the touch pad.
You'll need to take the laptop apart.
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
Jun 06, 2012 | Sony VAIO Computers & Internet
My compuer Sony Vaio VNG-TXN25N doesn t sound anymore.
Hi solesantelic...
Look for the speaker icon on your desktop in the right bottom portion of the sceen.
When you find it, RIGHT click on it, you will have two choices to make, choose and check each one of the choices to make sure that NONE of the boxes on each
choice has a checkmark in Mute,if there is a check mark then uncheck it
After that is down, then LEFT click on the speaker icon and make sure that the slider is all the way to the top and that the Mute does not have a check mark,if it does remove the check.
If that does not work the re-install the audio driver for your computer.
Please take time to rate me thumbs up
Sep 12, 2011 | Sony VAIO VGN-TXN25N/B PC Notebook
How to remove hard drive from Sony Vaio Laptop VGN - NR110E?
On the bottom of the laptop there should be a cover for a quare or rectangle shaped slot, most likely with two screws in it. Unscrew these, and the hard drive bay will come loose. Just unscrew it from the bay and it should be free.
May 02, 2011 | Sony Vaio VGN-NR110E/S Notebook
I need to remove the hard disk and to replace it because it is bad. How do get to it to remove it? I don't see anywhere it is accessible.
most sony laptops either have the hard drive internal and either access is via a back plate with a few screws underneith or you have to undo all bottom screws then were the track pad is the top borrom half with either come away reveling the hard disk or the complete bottom will come away.
Feb 11, 2010 | Sony VAIO VGN-N220E/W Notebook
Need service manual or instructions on replacing hard drive on a Sony Viao VGN-ns135e or Sony VGN-NS100 Series Laptop
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Nov 30, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
Replace the hard drive
remove all the screws in it and gently remove the cover.
Jul 08, 2009 | Sony VAIO VGN-NR285E/S 15.4" Notebook PC...
Bios setup password
you need to remove the the CMOS BATTERY from the motherboard and re insert will reset the BIOS password...
Apr 27, 2009 | Computers & Internet
Removing the hard drive to a Sony VAIO VGN-S660PNotebook?
On this line of Sony models replacing the hard drive is a pain because the computer must be taken completely apart to get to the hard drive. It is located under the palm rest. I looked up the Sony manual for this model and it does not show how to replace the hard drive -- meaning it should only be done by a trained tech.
You'll have to remove all the screws from the bottom and underneath the keyboard. Carefully detach the keyboard and set it aside. Once all the screws are remove from the laptop you should be able to separate the top of the casing from the bottom, this usually requires a small amount of force but too much force will crack the plastic! Underneath you will find the hard drive cage.
Also, some laptop vendors like to pull the 'hidden screw' trick! There may be a screw underneath the CD-rom drive so that may have to be removed or under some of the rubber feat on the laptop.
I couldn't find a photos or manuals that show how to do this, but these guys say they have a manual for a small fee.
They want $5.99 for the manual but that is much cheaper than paying a technician to do it for you.
Good luck and be careful!
Nov 13, 2007 | Sony VAIO® VGN-S660P/B PC Notebook
Sony VAIO  VGN-TXN25N/B PC Notebook Logo
1,083 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
