Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Srd522 ice maker not working need wiring digram
I turned the ice maker off now I can't get it to turn on and work it freezes cubes but won't dump them in ice been
Ice maker harvest cycle is not working. Jammed timer in Ice maker unit.
Remove the wire harness of the ice maker and put it back after 5 minutes. See next day whether it is working.
If not still working. You did the right needed thing at the wrong time to shut off the ice maker. You will have to replace the ice maker.
Ice maker units are very sensitive units. Sorry to say.
Oct 23, 2017 | Refrigerators
The ice-cube maker on our Sub-Zero 611 has stopped...
i have a ice cube Machine (40 Cube) But he not working Properly
I dont know the Warring Daigrams in this Machine Athore Parts is Very well Conditions plz Solution My Probalms
i Need the Simple Wiring Digrams
Thanks & Regards
9816319449
Aug 05, 2012 | Sub-Zero Refrigerators
I have had 3 ice makers installed in my fridge all have gone out unsure what to do to fix this problem if the icemaker just needs replaced or if there is something else causing my ice maker not to work
there may be a short in the wiring somewhere causing the ice maker to malfunction.I would try one more ice maker kit and replace all the components of the ice maker.
then have all the wiring checked.
Aug 29, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
My icemaker is not working... we had to disconnect the refrigerator to move it and the ice maker has not worked since we plugged it back in..
You may need to re-jump the ice-maker, with a jumper wire to get it to start, some ice-makers need this. You'll just get a piece of coated wire, with both ends twisted. There should be two holes by the ice-maker gear, stick both ends of the wire into each hole. This should re-start the ice-maker, leave it in, until the ice-maker gear starts moving by itself. You may or may not, need to hold the freezer door button in.
Mar 29, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Wiring digram for under counter uline ice maker
It is on the back of the machine, if you have clear ice maker, it may be on the back of the front plate.
Jan 20, 2010 | U-Line Refrigerator Ice Maker
No ice being made. water supply for drinking is OK. Model is about 3 years old. question: why no ice. does the automatic shut off arm control the water flow?
Well first of all you can check to see whether the ice maker has been turned off, Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat. Please reply if you need more help or information.......
Good Luck!!
Thanks
Dec 29, 2009 | LG LFX25960ST Stainless Steel French Door...
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Jun 30, 2009 | U-Line BI-95
Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Amana SRD522
sounds like water line is blocked with frozen ice. have a technician clean the line and check the icemaker and water line for any kinks.
Jul 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
26 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
