Question about Dishwashers
My Whirlpool dishwasher will not drain.what are the possible causes?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
Make sure the drian tube is coneected to the sink drain as high as possible. It can't be low down as you may think.
Posted on Jul 28, 2010
Backed up dishwasher
My Dishwasher is Backing Up with Water - YouTube
? 2:08
https://www.youtube.com/watch?v=JtbbEGo-X1w
Mar 4, 2014 - Uploaded by Appliance Princess
My dishwasher is backing up with water. What do I do? First thing you do, turn off the dishwasher. OK, I get ...
Is Your Dishwasher Not Draining? Try These Three Tips ...
https://www.discovercabrillo.com/is-your-dishwasher-not-draining-try-th...
Sep 23, 2015 - If you see a lot of standing water at the bottom of the dishwasher in your ... that prevents water from your sink backing up into your dishwasher.
drainage - What is causing my kitchen drain to back up into ...
diy.stackexchange.com/.../what-is-causing-my-kitchen-drain-to-back-up-...
Apr 25, 2014 - That air gap above sink level prevents water backing up into thedishwasher and prevents a vacuum sucking water back into the dishwasher.
I Fixed Our Dishwasher! Here's How I Did It... - Household Tips
https://household-tips.thefuntimesguide.com/2006/07/fix_dishwasher.php
Jan 19, 2016 | Whirlpool Dishwashers
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
My whirlpool quiet porter II dishwasher doesnt drain completely
not much info to go on but here goes...usually that problem is because the drain line into sink or whereever is too low. must go up from D/W soonest and go as high as possible.then into drain system.prevents drain back into D/W.also drain can be plugged up.. (hose) good luck ...paul
May 21, 2010 | Whirlpool Dishwashers
After final rinse on my Whirlpool dishwasher panel went dead
Check your main power input. Switch off and ON. If no display
Internal fuse / circuit would have tripped.
Try replacing / Resetting. No improvement contact service center for assistance.
Apr 16, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
I have a DU943PWKB0 Whirlpool Dishwasher that will not drain. It appears to be opperating but the unit will simply not drain the water. Could be the pump or possibly a clogged drian I guess. How can I...
MOD DU943PWKB0 WHIRLPOOL PROBLEMS
My Whirlpool dishwasher is not working. I pulled it out and when I leaned it forward it seemed to work once againe, but once I placed it back into it's slot it would not come on. Checked the wiring and everything seems fine. Unsure of what i should do.
Mar 04, 2010 | Whirlpool Dishwashers
Stopped runing
If you Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's electronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
Feb 22, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
if you hold the start button in it should reset,possible cause could be a blockage in the pump or drain outlet under the sink where the drain hose connects.hope this helps.
Mar 05, 2008 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
