Question about Home
I have turned my shower on by the diverter then the water just stops. I release the diverter and the water comes out of the facet. Then I pull the diverter up the shower comes on and then a few seconds later it turns off again. What can it be? I have already replaced the diverter thinking it was that. But it keeps happening?
  • 31 Answers
It is air in the line. I had the same problem. To solve it you need to find the main water valve in your house, usually in the basement, and shut it off. Then go to the faucet that is giving you the problem and turn on both hot and cold and let them run for a few minutes until there is no water coming out. Leave the faucets turned on and then go back to the main valve and turn it back on. You will hear sputtering noises as the water starts coming back through. Let it run for a few minutes. I had to do it a couple of times to get all of the air out. if that is not working, then you should try to do the same thing, but also open and drain the lowest faucet in your house, like in the basement. Hope that helps. It worked for me. <!-- from fixya rte -->
Posted on Aug 15, 2010
Bathtub diverter not working
After you use the diverter to get the water to the shower head, you leave it alone. When you turn the water off the diverter will automatically go back to its default position of faucet.
Sep 15, 2017 | Home
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Water flow interruption in shower diverter
The washer on the diverter is loose. needs to be tightened or replaced
Sep 12, 2009 | Home
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Bath tube plumbing is making vibrating sound then shutting off
Replace the cartridge even if its new. The vibrating is from the internal workings of the stem. It also effects the volume of water.
good luck, Phil
Dec 11, 2008 | Plumbing
Home Logo
121 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
