Question about Sewing Machines
Bobbins I am using my moms sewing machine a kenmore model 1264490 and I cant figure out how to get the bobbin out and add more thread... I have a bobbin with thread but cant get the machine open to re thread....
  • 106 Answers
Have a look at this website on the threading page, if your machine is not listed look at some of the other Kenmore machines and you will get the idea of how to remove the bobbin case. Basically you will find a small latch across the front of the bobbin case, pull the latch away from the case and hey presto.
www.sewusa.com
Posted on Apr 24, 2008
I cant figure out the bobbin part getting thread to come up to the needle please help or how to do the whole bobbin thing
Depending on the brand of machine, you insert your bobbin into the bobbin holder, thread the top part of your machine, including the needle, then turn the wheel on the side of the machine by hand and it will catch the thread that is in the bobbin and it will pull it up through the bobbin hole. Once it is pulled up through the hole, near your needle, you will pull the thread towards the back of the machine and leave it. Then start sewing.
Jun 09, 2016 | Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Kenmore cant thread bobbin
Sounds like you haven't engaged the bobbin into the wheel that runs the threader...
I had to pull the thread thru one of the little holes of
the bobbin and run the machine carefully to get it to
start threading.
Hope this helps.
Apr 26, 2009 | Sewing Machines
Thread breakes all the time will not sew
Try using a different bobbin. I just started sewing and was having the same problem. I ask my mom who has been sewing for about 40 years, and she said if the bobbin is wound to tight or if you are not using good thread it will break. I re-did the bobbin and wound it slow and it has been working just fine every since.
Feb 22, 2009 | Kenmore Sewing Machines
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
131 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
