Question about Intel Motherboard
We have a Intel SR2526UR Mother board and a 5630 chip set we cannot update the BIOS from the Intel Assistent or from the comand line. What am i doing wrong?
  • 73 Answers
I can't remember if this is the case but check to see f there is a jumper on your motherboard that needs to be enabled/disabled before you can update. Also some came with a type of "Anti-Virus" in the bios that must be disabled before update.
Posted on Jul 28, 2010
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
Display problem . i change ram & smps&i install extrenal vga card but no dispaly
Hi, Thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again, if theproblem same install the ram to another computer either it damage or not .Ifthe problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold" on off "switch for 40 seconds. Install battery again and start pc.
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.clip_image003.jpgclip_image004.jpgclip_image005.gif
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the bad capacitors, besidethe processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htm clip_image007.jpg http://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svg clip_image009.jpg http://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent markerbecause you need to remove and install it. It could not be possible for allmother board. clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again. It could not be apply for all mother board. ONLY FOR INTELPLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blinkfrequently in a long times or not.
If the floppy drives led light on, download updated bios your Intel motherboard, and use a floppy disk for restorethe bios , Download link. http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22 .
5. Don't switch off your motherboard atthe time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmosjumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm http://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htm Now switch on motherboard, hope, through these processes,should recover the mother board.
If the problem is same, try to install a graphics card. For same problem I will recommend you for new motherboard.
Hope this helps, .Reply me for another instruction. Thanks.
Feb 25, 2011 | Intel D945GCL Motherboard
I have an old PC with VIA VT82C693A motherboard,256MB SDRAM and Pentium 3 CPU. I connected all the peripherals correctly and started the system. The CPU and the fans are working.The CD-ROM is...
Hi,Thanks for using fixya,
Switch off the computer and open the pc cover.
First check the ram,and clean by eraser or with solvent and install again.If the problem is same, install the ram to another computer to ensure either it damage or not .If the problem is same change ram.
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmclip_image007.jpghttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image009.jpghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blink with a long times or not.
If the floppy drives led light on, download updated bios your Intel mother board,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmos jumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNow switch on motherboard, hope, through these processes,should recover the mother board.
Feb 19, 2011 | Computers & Internet
Mother can not boot up. bios is damage
Hope this helps,.
Thanks for using fixya.
Feb 18, 2011 | Gigabyte GA-K8NE (04719331711023)...
Video problem
Hope this helps,.
Feb 18, 2011 | MSI K8MM-V Motherboard
My ga-81915me main board canot power on, power suplly is work good
If its Under Warranty Period then try to claim the Warranty .
Or
Else you have to give it to a Service Center
Hope This Helps
Jan 29, 2011 | Gigabyte GA-8I945P-G Motherboard
Bois update
Go tlo Intel site, insert *********** board model, processor and OS you are using and you will get all data/updates there. But my advise would be to not try to update your BIOS unless you are facing any problems and a message suggests a BIOS update. Its not generally required unlees the MB & Processor isoutdated, but your PC will always prompt you if that is the case. Do it if only prompted to....sodeep
Mar 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
865 mother board sound driver
The fact that the driver is not being prompted or autoloaded by the OS tells me you might have to enter the BIOS and enable the sound features. Sometimes they are off by default. I would also look for an updated BIOS while I was at ASROCK the real maker of your board.
try this site
Jan 04, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
Requared bios updated versin for foxconn 865gv chipset mother board
Hi, I run a foxconn mobo myself and yes its a great board. But dont go to the foxconn site looking for downloads. instead go to the VIA site they make the chips and you will get more sense there. If all else fails Foxconn do have a "Contact us " link on their home page. This will give you the company email address and you could request directions to the update site there, the only trouble is it could take weeks to get a response. Regards mistyman
Aug 20, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
